Author: Subject: Cortina hubs with different PCD and hub diameter
Jeffers_S13
posted on 10/2/17 at 02:35 PM Reply With Quote
Anyone on here know of place that will make me some with a 4 x 114.3 PCD and hub dia of 66.1 mm ?
Obviously I could buy some standard ones and then get them re-drilled and maybe make a very slim hub sleeve but I'd prefer if they were made to suit whilst still in the chuck that turned them. Might also want a bit extra meat to the OD of the hub face.
James
[Edited on 10/2/17 by Jeffers_S13]
Build pics : http://tinyurl.com/fuyh6
posted on 10/2/17 at 06:20 PM Reply With Quote
Is it worth checking out P100 hubs , I know the have a different PCD?
sdh2903
posted on 10/2/17 at 06:52 PM Reply With Quote
Hi spec make cortina hubs am sure they would make some to your requirements. Only problem is they are a complete pain in the arse to deal with.
Minicooper
posted on 10/2/17 at 07:41 PM Reply With Quote
I think Rally Design do some blank alloy hubs for the Cortina which can be drilled within reason to any pcd
bart
posted on 11/2/17 at 01:23 AM Reply With Quote
Hi . Just re-drill new pdc in the space between originals. Then turn sum spacers for middle.
Simples
BE ALERT > BRITAIN NEEDS LERTS
redscamp
posted on 12/2/17 at 02:26 AM Reply With Quote
Cortina P100 has 5 stud flanges + 5 hole discs (P100 solid Granada vented) the discs were hard to buy at the time, Sierra P100 discs invariably offered by motor factors.
