Author: Subject: cold start flooding a little help please
legend
posted on 10/2/17 at 09:46 PM Reply With Quote
hi having a spot of bother with flooding with my 2l zetec on twin 45s when cold is it 2 pump on throttle how far down? then part down and crank? or may need new plugs are these ok non platinum NGKTR5A-10?
benchmark51
posted on 10/2/17 at 11:02 PM Reply With Quote
I have a pinto 2L on dello 40's and I do 1 pump, crank and tickle the throttle when it fires. When all have kicked in it's fine, 1st time start all day. I changed from bosch to champion last week and it pulls much better. Summer time it starts very easy.
posted on 11/2/17 at 12:23 AM Reply With Quote
Why on earth would you think changing to old style plugs would be of any benefit? The benefits of precious metal plugs are they require less KV and maintain their gap over very high milages and double platinum or double iridium plugs can go the life of the car without changing or re-gapping.
If it dosen't fire on the first or second attempt do a clear flood holding the throttle wide open as you would on any carb equiped engine. If the engine is flooding very easily you need to check the carb float levels and fuel pump presure also the idle jet size. Weber DCOE carbs are designed to work at quite low fuel pump pressures 4 psi is the absolute maxium 2.5 to 3.5 psi is ideal. I would also do a stress test on the coil to make sure the coil is outputing sufficent KV on each of the four towers and water mist spray test on the coil and plug leads.
[Edited on 11/2/17 by britishtrident]
perksy
posted on 11/2/17 at 11:20 AM Reply With Quote
On mine I pumped the accelerator pedal twice and then slowly pressed the pedal down for the third time whilst starting the car, Worked everytime..
Do you have a fuel pressure regulator fitted ?
Have you checked the floats in the carb's for damage and correct set height ?
[Edited on 11/2/17 by perksy]
