Author: Subject: 2005 ford transit connect 220 Towing
Dave Bailey
posted on 12/2/17 at 10:02 PM Reply With Quote
I need to get a van and have been offered a really low mileage tdci. Do you think this would be capable of towing a 7 on a trailer?
Dave B
ian locostzx9rc2
posted on 12/2/17 at 10:12 PM Reply With Quote
Yes it should be capable of towing a 7 on a lightweight trailer with brakes
chris
posted on 12/2/17 at 10:14 PM Reply With Quote
whilst it will pull it the van is just not big enough a case of tail wagging the dog
minitici
posted on 13/2/17 at 09:08 AM Reply With Quote
Transit Connects have very low towing capacities (800Kg).
You would probably need a light trailer to keep the weight below.
Vans are more likely to be pulled for weight checks!
Banana
posted on 13/2/17 at 01:07 PM Reply With Quote
Our 70bhp Citreon Berlingo happily towed an MK - on a twin axle trailer.
minitici
posted on 13/2/17 at 01:19 PM Reply With Quote
I too have a Berlingo and it has a decent 1300Kg towing capacity.
loggyboy
posted on 13/2/17 at 01:48 PM Reply With Quote
Might be tight, it only has a 800KG tow weight, so would defo need to be a light trailer.
And with a Gross of 2240 - minus the van at 1415, and trailer at 800, only leaves you a few kgs of load in the van.
[Edited on 13-2-17 by loggyboy]
Mistral Motorsport
Dave Bailey
posted on 13/2/17 at 02:46 PM Reply With Quote
Thanks for the replies guys... helpful as usual... I went to have a look at it this morning based on the advert
0ne owner, 11000 miles 2005 in as new condition... I was dubious about the mileage so mailed 'Michelle' to confirm it was correct and she said yes had very little use...
So turn up to view... it's a 2 owner with the first being British gas and it has done 110,000 mile... and the bloke showing me the vehicle was Kevin who must be Michelle only at the weekends!
What a total waste of time!
posted on 13/2/17 at 02:51 PM Reply With Quote
Next size up next good? Mate of mine has a Citreon dispatch he uses for his crossers.
Or maybe a git big one that the car will go in the back of? Most of the high top long wheel base ones have a 3.5t towing capacity and big old mam...
posted on 13/2/17 at 05:04 PM Reply With Quote
We have a Transit Connect at work. It's an OK little van, but it's lightweight and I'd be worried about a trailer having an effect on it's stability.
ian locostzx9rc2
posted on 13/2/17 at 05:25 PM Reply With Quote
Didn't realise they could only tow 800kgs with is pretty useless better of with a diesel Astra which can tow 1150 kg
