Author: Subject: R1 Carbs - TPS Query
Dick Axtell
posted on 13/2/17 at 12:53 PM Reply With Quote
G'day Everyone, especially those who have fitted R1 carbs.
This question concerns the Mikuni TPS potentiometer, on the end of the throttle shaft. Because I needed to ID which of the 3 wires did what, I carried out the usual multimeter resistance check. For the case where the initial resistance is low, moving the throttle shaft should give an increase in resistance. However, I get very 'variable' and possibly erratic values, which seem to disappear when the shaft stops rotating.
Is this normal? Should I start looking for another TPS? I would like to be sure that everything works as it should, before I commit to assembly work.
Ugg10
posted on 13/2/17 at 01:15 PM Reply With Quote
Usually two pins are earth and live (12v/5v) and the other is the wiper, so based on info below for '98 R1 test connecting pin 1/3, move the pot and see if the resistance goes up or down, check 2/3 this should go the opposite way with fully open and close being the same but opposite.
That said it should be a smooth change whichever way you use it.
Not sure this is much help, sorry.
http://www.r1messagenet.com/forums/pdf/02r1TPS.pdf
http://www.rtuna.co.uk/forum/manuals/R1%20Service%20Manual%2098-99.pdf
Page 260 - Standard resistance looks like it should be between 0 and 5K Ohm
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Dick Axtell
posted on 13/2/17 at 01:58 PM Reply With Quote
Hi Ugg10,
Thanks for that useful info. Will check according to the manual's spec.
