Author: Subject: Sierra diff question AGAIN
Charlie_Zetec
posted on 16/2/17 at 05:17 PM Reply With Quote
Evening all, I'm after some brain-picking regarding Sierra diffs. Before anyone pipes up and says "use the search function", I already have, and read through the 7th Heaven website, but still can't find a direct answer to my quandary.
I've been offered the rear diff and shafts from a 2.0l DOHC Sierra Sapphire. I'm told it's a 4x4, but am unable to verify this as am not near the vehicle geographically. I have the vehicle reg number if that helps, but don't want to post here in a public forum as I'm not the owner of the vehicle. The tag on the diff cover isn't legible. Seller says it has bolt-on shafts, and has sent me the following picture, that *looks* like the shafts are (rusty) bolt-on Lobro units.
Diff & flange (from rear)
Can anyone confirm whether this is likely to be a 7 or 7.5" unit? I thought 4x4 Sierras used a 3.62 ratio LSD with 100m flanges, but can anyone offer FACTUAL knowledge please.... Don't really fancy the long journey Sunday to find it's not a LSD, or uses 108mm flanges.
Assuming it's the correct type, I'll be sending away for overhaul (upgrade) - so my standard 3.62 LSD will be for sale in a couple of weeks if of any interest to people on here.
Thanks!
[Edited on 16/2/17 by Charlie_Zetec]
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
posted on 16/2/17 at 05:51 PM Reply With Quote
Ask him to run a ruler over the width of the top mounting as that's either 7 or 7.5.
Can he also run the ruler across the lobo and check that as well?
Midlana when I find the space...
Charlie_Zetec
posted on 16/2/17 at 05:59 PM Reply With Quote
I did ask him to check if it was an open-faced 7" chamber with a single top bolt, and was told it was, although he couldn't get exact measurement across.
All the hints suggest I'm on the right track, but didn't know if anyone might k ow from the car model itself - assuming it's not a Friday night Dagenham special!
mark chandler
posted on 16/2/17 at 07:23 PM Reply With Quote
Bolt on half shafts, 4x4 Sierra my money would be on a 3.65 LSD
Barkalarr
Contributor
Posts 853
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 16/2/17 at 07:47 PM Reply With Quote
Charlie - what diff are you after ? Drop me a text - I've got 5 of these in the workshop in various guise and I'm a lot lot closer
Neil
snapper
posted on 17/2/17 at 10:18 AM Reply With Quote
If it from a 2.0L DOHC 4x4 it is a rare 3.9 viscous LSD
SVA passed first time... Trousers in the wash to remove stains
Charlie_Zetec
posted on 17/2/17 at 10:35 AM Reply With Quote
That's the sort of good news I was hoping for! Fingers crossed, will find out Sunday when I collect exactly what my hard-earned cash has *potentially* bought me....
theduck
posted on 17/2/17 at 11:07 AM Reply With Quote
Could be interested in your current one if all pans out with this one.
Charlie_Zetec
posted on 17/2/17 at 03:51 PM Reply With Quote
Will update Monday eve, but will bear this in mind!
