Author: Subject: leaky brake hose?
rodgling
posted on 20/2/17 at 04:52 PM Reply With Quote
leaky brake hose?
Just spotted this on a front brake hose:
There is a yellowish stain underneath the clear plastic outer coating. Is this indicative of a leak or just some random discolouration? Should I replace it?
[Edited on 20/2/17 by rodgling]
gremlin1234
posted on 20/2/17 at 09:04 PM Reply With Quote
if you look carefully, there are similar colours further down the pipe
but my question is
why does it appear to be in a section of fuel pipe?
(guess is as protection when it is mounted to something) but looks odd
edit: also note that to fit that fuel pipe around the braided hose, one end of it/them must have been removed/replace, so certainly check the hoses further
[Edited on 20/2/17 by gremlin1234]
Gre3D
posted on 20/2/17 at 09:39 PM Reply With Quote
i wouldn't worry about it too much. the inside is a teflon liner... i dont think that is going to leak, and if it would leak i dont think it would appear like that
SteveWalker
posted on 20/2/17 at 10:05 PM Reply With Quote
Originally posted by gremlin1234
edit: also note that to fit that fuel pipe around the braided hose, one end of it/them must have been removed/replace, so certainly check the hoses further[Edited on 20/2/17 by gremlin1234]
That piece of fuel hose looks slit to me.
rodgling
posted on 20/2/17 at 10:48 PM Reply With Quote
Exactly.
russbost
posted on 20/2/17 at 10:49 PM Reply With Quote
Looks like discolouration of the outer PVC sheath to me, I've seen similar b4 particularly on the clear coat as any stain will show up, rust is a common staining agent. I've never known a Teflon lined pipe to leak, but if it was then it would fill up the inside of the whole PVC sheath & either leak out of the ends where the crimps are, or would blow up & burst like a rubber hose would
rodgling
posted on 20/2/17 at 11:16 PM Reply With Quote
Thanks, I think you are right.
Unfortunately it leaves me no closer to identifying the source of my leak (clues include a *very slight* sinking pedal and tiny (a few drops) puddles when parked up after a long drive... it ought to be easy to locate but strangely isn't.
russbost
posted on 21/2/17 at 08:06 AM Reply With Quote
1st clue is the location of the few drops, won't necessarily reveal the source of the leak, but gives a starting point to work back from
gremlin1234
posted on 21/2/17 at 10:00 AM Reply With Quote
Exactly.
ah, that will be why it has a cable tie too :-)
