Author: Subject: Hayabusa upgrades
deanspoors
posted on 23/2/17 at 06:40 AM Reply With Quote
Hayabusa upgrades
Wanted - engine parts for a supercharger upgrade on a gen 1 hayabusa 2005 engine, e.g.
Turbo pistons
uprated Valves, springs, retainers, etc
steel Con rods
uprated 690/725cc injectors
uprated gearbox parts
uprated clutch assy parts
head studs, nuts
Just looking to see if there is anything out there before I buy new.
Dean
jeffw
posted on 23/2/17 at 10:09 AM Reply With Quote
If this is for your Rotrex build you don't need the pistons Dean.
There is no reason why you can't run a bigger pulley that optimum to decrease the boost pressure you get while you sort out what strengthing in the engine you actually need.
[Edited on 23/2/17 by jeffw]
deanspoors
posted on 23/2/17 at 10:40 AM Reply With Quote
Hi jeff, thanks for the advice. Ideally as the conversion is going to take quite a bit fabrication, i'd like to just get it all done in one go. I am hearing so much conflicting advice, it's hard to know what to go for. Some people are saying just got for a cylinder barrel spacer and others are saying rods and pistons are a must. obviously theres £1400 difference in those two options so I don't want to buy them if I don't need to, but don't want to do the mod cheaply either
jeffw
posted on 23/2/17 at 12:51 PM Reply With Quote
Go with the advice from someone who has actually done it and not confusing it with a Turbo build....there is a guy on uphillracers who has run one for several seasons.
kingster996
posted on 23/2/17 at 02:36 PM Reply With Quote
Hasn't Nick got one in his DJ Dean?
[Edited on 23/2/17 by kingster996]
I used to be indecisive, but now I'm not so sure
jeffw
posted on 23/2/17 at 03:32 PM Reply With Quote
Nick Algar does but it runs on Methanol with no intercooler so probable isn't the one to copy.
