Author: Subject: Striker pinto engine mounts
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 3/3/17 at 07:22 PM Reply With Quote
Testing the water
Anyone got some Striker pinto engines mounts gathering dust .
Please pm me
obfripper
posted on 3/3/17 at 09:48 PM Reply With Quote
Are they the same as crossflow ones? Escort xf ones work on a pinto in an escort, but i'm not sure with a striker if the same applies.
I have sylva crossflow ones knocking about somewhere, if they're of any use make me an offer.
I take it you've got the later chassis with rubber bobbin mounts bolted flat to the chassis?
If you have the early chassis with welded in cradles for original escort mounts, it should be ok with a pinto on xf mounts, iirc the pinto is slightly wider so different rubber bobbins may be needed to locate correctly.
Dave
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 3/3/17 at 10:15 PM Reply With Quote
Hi Dave
Would be for the later chassis without the cradles
benchmark51
posted on 3/3/17 at 10:17 PM Reply With Quote
I replaced a xflow engine in my locost with a pinto using the same mounts, no problem. I had bought the aluminium sierra mounts and bobbins but didn't need them.
wylliezx9r
posted on 3/3/17 at 10:29 PM Reply With Quote
Pinto in a Stryker......... Sacrilege
George Best
benchmark51
posted on 4/3/17 at 09:45 AM Reply With Quote
Go on, Strykers aren't that bad.
wylliezx9r
posted on 4/3/17 at 10:29 AM Reply With Quote
George Best
pekwah1
posted on 4/3/17 at 12:21 PM Reply With Quote
I've got some from a CVH, dunno if these are any good?
