simon h
posted on 15/3/17 at 09:49 PM |
FS - Toyota 2ZZ-GE engine and RWD conversion parts
I have a circa 2004 Toyota 2ZZ-GE 190bhp engine taken from an Elise that had done around 10000 miles for sale. I have the engine loom, a piece of
chassis loom and a Lotus ecu that should run it but would be best to get it tuned to suit the changes you make either with the Lotus ecu or getting an
Emerald or similar to run it using the Lotus ecu cut up to make an adapter.
The engine has been dry stored in my garage for some years and I make no guarantee's but it was fine when stood. I have put a little oil down
the bores and turned it over by hand occasionally.
I have the following to convert this to RWD.
Cast ally 2ZZ to Type9/Caterham 6 speed bellhousing
Paddle clutch
Machined ally dry sump pan (or you could shorten the wet sump) You will need to source and mount a dry sump pump.
Various parts to weld up to make a set of engine mounts
A 4/2/1 tubular exhaust manifold
MAF meter in an HKS (I think) intake tube (needs some silicone tube and a filter to finish off)
There are also various bits and pieces that I will throw in that may be useful.
The price for this package is £750 collected.
In addition I have a TRD lightweight flywheel for an additional £150
I can supply pictures to anyone interested but it is best if you come and have a look really.
Stevie_P
posted on 16/3/17 at 09:16 AM |
May be worth putting this on the MR2 Roadster owners club site as the 2ZZ is a popular conversion.
If you want I may be able to post a link up for you?
simon h
posted on 16/3/17 at 09:30 AM |
Could do, thanks.
I would sell the engine without all the RWD conversion stuff, as they wouldn't need it, for about £500 I think.
Stevie_P
posted on 16/3/17 at 09:36 AM |
Hi Simon
I've posted as link on the website. Best of Luck.
Tempted yself as I have an MR2 but got so much else on at the moment.
simon h
posted on 16/3/17 at 09:39 AM |
Thanks Steve.
simon h
posted on 30/3/17 at 04:07 PM |
[Edited on 30/3/17 by simon h]
simon h
posted on 30/3/17 at 04:13 PM |
Tried to add some pics but cant get it to work.
There are some in my archive if anyone is in the slightest bit interested in the package before I put it on ebay or something!
r1_pete
posted on 30/3/17 at 06:15 PM |
Just copy and paste the [pg...........pg] description above your archive picture into the post
[Edited on 30/3/17 by r1_pete]
simon h
posted on 23/4/17 at 11:53 AM |
Standard engine sold. RWD parts still available.
High comp 2ZZ-GE engine available.
simon h
posted on 16/5/17 at 01:48 PM |
All sold
