Author: Subject: Sierra 1.8L CVH ignition puzzle?
novicebuilder
posted on 19/3/17 at 01:20 PM Reply With Quote
In my Haynes roadster I have a 1991 1.8ltr CVH with all the donor engine electrics and original ECU. Car will usually start easily and run smoothly, but after a while the engine stops and there is no ignition spark. Leave car for a while and it starts again fine - Why? Any bright ideas from experts out there.
I thought it was probably an old wire from the 26 year old donor engine wiring but why would it work fine and then engine just stop while car is sitting idling and not even moving?
I have had a basic look at my wiring but not undone everything to check every join (yet). I have replaced Ignition coil, spark and HT leads and spark plugs, but problem not gone. I tried a new ECU but this didn't help. I wondered if ignition coil could be overheating, but it is a new Ford part for this model of engine and doesn't feel hot at all. It sits in a well ventilated part of the engine bay.
I wondered about getting a diagnostic tool for the car, but not sure still available. It seems that something changes in the car and it is not consistent when it happens. I wondered if the security system from the original car was activating an ignition lock, but can't see where this would be happening.
Useful suggestions gracefully received - Thanks
gremlin1234
posted on 19/3/17 at 02:01 PM Reply With Quote
is it happening when an electric fan is trying to kick in?
novicebuilder
posted on 19/3/17 at 02:03 PM Reply With Quote
no
gary gsx
posted on 19/3/17 at 02:12 PM Reply With Quote
Not sure but hasn't the distributor got an amplifier unit on it if so that may be overheating.?
Gary
novicebuilder
posted on 19/3/17 at 02:17 PM Reply With Quote
Car doesn't have a distributor, spark is distributed through rotor arm on front of camshaft.
gary gsx
posted on 19/3/17 at 03:10 PM Reply With Quote
My mistake I was thinking of the old xr2s etc driven on other end
Gary
plutos3
posted on 19/3/17 at 03:20 PM Reply With Quote
Is the ignition amp mounted on the same ali heat sink plate as the coil
gremlin1234
posted on 19/3/17 at 03:25 PM Reply With Quote
that is a distributor
how is the cam / crankshaft position measured?
novicebuilder
posted on 19/3/17 at 05:29 PM Reply With Quote
There is a crank position sensor on the toothed wheel of the crankshaft, which feeds into the ecu.
Pluto 3 - I'm sorry but I don't understand the question "Is the ignition amp mounted on the same ali heat sink plate as the coil" could you explain further, so I can answer. The coil is anchored to the chassis in the engine bay with most of the coil sitting below the upper rail of chassis in free space.
posted on 19/3/17 at 06:41 PM Reply With Quote
Both the crankshaft position sensor and the ignition amplifier module can be affected by temperature
novicebuilder
posted on 19/3/17 at 06:50 PM Reply With Quote
I now realise the ecu is the ignition amplifier. It is mounted separate from the coil on the aluminium sheet that forms the front of the scuttle into the engine bay.
The crank position sensor is in a well ventilated part of the engine bay, so I wouldn't expect it to get any hotter than normal.
Is there a diagnostic test I can do to check the crank position sensor is working correctly?
Is there any other diagnostic test you recommend so I can find what it is that is stopping spark?
Dusty
posted on 19/3/17 at 09:44 PM Reply With Quote
The ESC Hybrid module that came with the 1.8 CVH doesn't have any security stuff built in. Just reads crank position, manifold pressure for load, air and engine temp, puts them all together and adjusts spark timing. It has an input from coil negative and outputs to a choke heater and a solenoid valve which both influence the carb. I would check/connect/disconnect these latter two carb controlling units.
novicebuilder
posted on 21/1/18 at 03:13 PM Reply With Quote
solution found
To complete the story in case anyone else has a similar problem, I have now solved this. I tested the signal coming from the crank position sensor to the ECU by a voltmeter over the feed wire and it was not sending any current at all. So I changed the crank position sensor and problem solved. It now starts first time everytime and continues to run without fault. Yahay! I solved it sometime ago but felt it might be good to post the outcome.
posted on 21/1/18 at 03:35 PM Reply With Quote
Nice of you to let others know that you have solved the problem, I have a pet hate for those that ask for advice and then don't let people know their advise has been helpful
SJ
posted on 21/1/18 at 04:24 PM Reply With Quote
I started out with a 1.8cvh and it wasn't half bad. Decent turn of speed and a nice sound.
novicebuilder
posted on 21/1/18 at 05:24 PM Reply With Quote
Glad it was appreciated. Hopefully it will help someone else at some point.
Car goes really well and I am delighted with the CVH.
