Author: Subject: Rev's slow to come back down 1.8 CVH Zx6R carbs
mikeb
posted on 20/3/17 at 09:45 AM Reply With Quote
Any suggestion why under zero load the rev's on my 1.8CVH take a little time to come back down.
I'm running zx6r carbs with Nodiz ecu, on a blip of the throttle it responds well just takes a couple of seconds for the revs to come back down to idle?
It's on standard jets (i've bought some 1.6mm to go in) with the idle screws 2.5 turns out.
It also bogs down underload after about 3.5k but assuming the jets and a rolling road would sort that.
M
redturner
Senior Builder
Posts 412
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 20/3/17 at 10:03 AM Reply With Quote
Sounds like you are under jetted, stick the 1.6s in or maybe some 180s.....
Slater
posted on 20/3/17 at 11:14 AM Reply With Quote
Have you got a throttle return spring fitted? Often needed for bike carb set ups.
Link to post
Norfolkluegojnr
posted on 20/3/17 at 11:48 AM Reply With Quote
Link to post
Yes, this. Having fitted two sets of bike carbs, both needed additional springs to help them close.
mikeb
posted on 20/3/17 at 12:19 PM Reply With Quote
I've got the extra return spring on the pedal end, the zx6r's seem to snap shut very well, so don't think that the problem.
I've seen teh zx6r also have adjustable needles, i've not found that adjustment yet, anyone know where its adjusted and the effect of adjusting over bigger jets ?
Would the jets affect the return to idle?
[Edited on 20/3/17 by mikeb]
CosKev3
posted on 20/3/17 at 12:40 PM Reply With Quote
The additional spring needs to be in the carbs, not the pedal.
Even though they do seem to snap shut my experience with the R1 carbs is you need a additional return spring on the carbs as on the bike they use twin cables
Norfolkluegojnr
posted on 20/3/17 at 12:49 PM Reply With Quote
easy way to check - rev it and close the throttle by hand, on the carb.
if its that, you wont get the slow rev drop issue, if you still do, its something else
SJ
posted on 20/3/17 at 01:00 PM Reply With Quote
I have Zx6R carbs on my Zetec & they work really well. The needles are adjustable by taking the carb top off and moving the circlip that holds the needle in either up or down. There are 3 or 4 grooves I think.
The effect of the needles position is on mid throttle mixture. At WOT the jet size determines mixture. At idle it is the pilot jet and float height, and everywhere in between it is a combination of the jet size and needle height.
Mine needed an additional spring on the carb to return quickly, though I don't have a spring at the pedal end.
Stu
mikeb
posted on 20/3/17 at 01:27 PM Reply With Quote
Thanks Stu, thats really helpful.
I'll pop the tops off tonight to see if I can adjust, handy for IVA to if it fails emissions!
r1_pete
posted on 20/3/17 at 01:46 PM Reply With Quote
Not that familiar with 6R carbs but done plenty of 9R and zzr carbs, while you're in there check the slides are nice and free and not sticking.
mikeb
posted on 20/3/17 at 01:54 PM Reply With Quote
any tips if they are a sticking a little?
kingster996
posted on 20/3/17 at 08:18 PM Reply With Quote
Carbs being out of balance can cause the revs being slow to drop too.
I used to be indecisive, but now I'm not so sure
r1_pete
posted on 20/3/17 at 08:35 PM Reply With Quote
If they are sticky, a good clean, and polish any rough areas with something like solvol autosol, Ive used T Cut with success too, but clean any residue away, both autosol and T Cut are abrasive enough to cause wear if left.
[Edited on 20/3/17 by r1_pete]
scudderfish
posted on 20/3/17 at 09:53 PM Reply With Quote
The throttle cable always needs to be in tension. Imagine you had no spring at all at the carb, the spring on the pedal would be trying to push the cable which will just bend and buckle wherever it can.
r1_pete
posted on 20/3/17 at 10:04 PM Reply With Quote
But you do need some slack to enable the throttle lever/cam to home on the tickover adjusting screw, under tension it will lift off, or be slow to settle, usually 2-3 mm at the cable stop is the norm.
Tatey
posted on 21/3/17 at 06:04 PM Reply With Quote
They other thing to look for is an air leak, I have had one on my ZX6R carbs. The way to check is with some WD40 or other suitable flammable spray and spray all around the carbs to see if the revs rise.
