Author: Subject: sylva striker crossflow manifold
striker1660
posted on 21/3/17 at 06:12 PM Reply With Quote
as per the title, preferably the original type sylva did and raw type will probably be the same. Also any other crossflow parts weg. lowered sump, lightened flywheel, rear cranksahft seal, sylva crossflow mounts. please mail with details
Dick Axtell
posted on 22/3/17 at 11:57 AM Reply With Quote
Originally posted by striker1660
....Also any other crossflow parts eg. ....sylva crossflow mounts. please mail with details
Here is pair of Xflow mounting brkts. Believed to be from a Fury. Any use to you?
XflowBrkt_01
XflowBrkt_01
XflowBrkt_02
XflowBrkt_02
I also have pair Xflow mounting brkts for old-style Locost chassis.
[Edited on 22/3/17 by Dick Axtell]
striker1660
posted on 22/3/17 at 09:05 PM Reply With Quote
Thanks Dick, will skip as i am not sure the base is right for the striker.
davspeed
posted on 23/3/17 at 10:55 AM Reply With Quote
This is what I have. I will be cutting off back to the chassis rails.
obfripper
posted on 23/3/17 at 02:00 PM Reply With Quote
I have a pair of crossflow mounts from my car, it's a 98 live axle chassis.
They've been stood around for about 12 years and have got a bit scabby, so want a good cleanup and repaint.
They were paired with a 4spd escort box, i'm not sure how much the 5spd would alter the positioning.
https://www.dropbox.com/sh/68jzmzn36m6hknp/AACTPsO0gFKZVsFRiCUcuSWaa?dl=0
I have a hi-flow twin 40's inlet manifold, it has had a trim on 2 mounting lugs where i had it bolted to an adaptor on a zetec.
I have a matched pair of dellorto 40's that are in good condition, they have not been used since rebuild, i replaced anything that was required at the time. They're jetted for a tuned crossflow, i'll have a dig around and see what the jetting was exactly, iirc they're 36 chokes.
I also have a cheapo 4-1 exhaust manifold in mild steel that was modded to side exit, i suspect you probably are looking for something a little more aesthetically pleasing.
If anything is of use let me know.
Dave
