Author: Subject: Advice from machinists please
johnH20
posted on 23/3/17 at 06:30 PM Reply With Quote
I need to make 4 x 40 mm holes in a sheet of 8 mm ali plate for an inlet manifold. I have drill press but my biggest step drill 30 mm - don't know if that would be up to the job anyway. Would some kind of hole saw work , if so what type? Any advice welcome.
leon51274
posted on 23/3/17 at 06:50 PM Reply With Quote
A decent metal cutting hole saw, plenty of cutting compound and slow the speed of the drill down should give you as good a job as any, other than laser or waterjet.
Oh and a good centre-pop mark so the drill bit doesn't wander on start up.
tegwin
posted on 23/3/17 at 07:34 PM Reply With Quote
I have used 40-70mm hole saws in 8mm steel plate without too much issue just go slow, keep it cool and clamp the thing down tighter than a tight thing!
www.verticalhorizonsmedia.tv
posted on 23/3/17 at 07:42 PM Reply With Quote
I made my inlet manifold from 12mm ally ,I used a woodworking coping saw to cut it out including the ports which I cut slightly undersized then blended into the ports.
40inches
posted on 23/3/17 at 07:45 PM Reply With Quote
Replace the drill in hole saws with a length of steel rod, and drill the pilot hole separately.
This stops the drill flutes enlarging the pilot hole
gremlin1234
posted on 23/3/17 at 07:46 PM Reply With Quote
this one says its suitable for steel and ali so should be fine, but for ali you may need to take it slowly
http://www.screwfix.com/p/makita-plumbers-holesaw-kit-6-piece-set/4689r
theprisioner
posted on 23/3/17 at 08:54 PM Reply With Quote
Mag or Annular hole cutters are better than hole saws way more accurate. Needs a good drill press with low speeds.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
posted on 24/3/17 at 08:54 AM Reply With Quote
As said, slow speed and hold the work piece very well. If it picks up and spins it'll hurt!
johnH20
posted on 24/3/17 at 07:36 PM Reply With Quote
Thanks chaps, plenty of good advice there.
AJC
posted on 25/3/17 at 08:44 AM Reply With Quote
I can get them machined for you if its not too urgent.
johnH20
posted on 25/3/17 at 05:26 PM Reply With Quote
Thanks for the offer AJC. I am still at the design stage. Also trying to get my runners to fit using standard bends. Very difficult installation.
AJC
posted on 25/3/17 at 06:57 PM Reply With Quote
Sounds complicated! If I can help send me an email.
