New Topic New Reply
Author: Subject: car ramps for all four wheels (DIY?)
Slimy38
posted on 28/3/17 at 10:10 PM Reply With Quote
I'd like to get my tintop into the air, car ramps seem like the easiest way to do it and would be high enough. But I want to get all four wheels to the same height, and the front of the car is 'incompatible' with normal ramps (the ground clearance on the bumper is too low).
So I was thinking of simply using ramps as stands, lifting the car high enough on a jack and then getting the ramps under the wheels. Seems like a reasonable plan, and it would allow me to put them under all four wheels (two at a time).
Then I thought do I need ramps at all? Could I weld something together that could hold the car up a similar height (about a foot or so).
It would be used with a 3 ton jack that can lift 520mm, so I can certainly lift it high enough to put something under the wheels, even with suspension droop.
Anyone got any suggestions, ideas, etc?
daviep
posted on 28/3/17 at 10:27 PM Reply With Quote
Big blocks of wood, far more versatile than a purpose made stand, you can stick them in any where and stuff won't slide on the like it does when metal on metal. I've got loads of different sizes in sets, the biggest are 450mm x 450mm x 600mm
A truly great library contains something in it to offend everyone.
Andybarbet
posted on 28/3/17 at 10:51 PM Reply With Quote
Like this ?
http://www.carlift-ramp-mr1.com
Or a shorter version of this maybe ?
www.hamercarlift.com
owelly
posted on 28/3/17 at 10:55 PM Reply With Quote
I have four big axle stands from Machine Mart and a big trolley jack. I can get my Transit 2' off the ground with no problems!!
http://www.ppcmag.co.uk
stevebubs
posted on 28/3/17 at 11:43 PM Reply With Quote
Meh...2 long pieces of wood that you drive the car on first to raise it to the right height for the lift to work...maybe with the middle bit (where the lift arms go) being removable... simple and effective..
stevebubs
posted on 28/3/17 at 11:45 PM Reply With Quote
Ah..misread...thought you wanted to use something like a lift to raise the car... ramp extensions might work for you.. (either make or buy) then just lift the rear end onto axle stands or another set of ramps using a trolley jack....
https://www.machinemart.co.uk/p/car-ramp-extensions/?da=1&TC=GS-051720001&gclid=Cj0KEQjwk-jGBRCbxoPLld_bp-IBEiQAgJaftbalcrGPHezSY8tGB4l5ZEJVL4 40tsRLQ-5F5eQYvLEaAsYT8P8HAQ
[Edited on 28/3/17 by stevebubs]
stevebubs
posted on 28/3/17 at 11:50 PM Reply With Quote
Another solution (similar to the MR1 above) http://www.locostbuilders.co.uk/forum/8/viewthread.php?tid=105193#pid877169
Slater
posted on 29/3/17 at 07:12 AM Reply With Quote
You could try 8 breeze/engineering blocks, laid on their side stacked 2 high, or railway sleepers cut up to give big blocks to stand all 4 wheels on. Obviously ensure handbrake is on and in gear so car does not roll off.
Slimy38
posted on 29/3/17 at 08:23 AM Reply With Quote
Originally posted by Andybarbet
Like this ?
I like that one!! A bit 'hicost' for me though, but definitely something to think about if funds allow.
I am wondering whether I'm overthinking things, whether Owelly's approach of four axle stands is the better option. But how safe are axle stands, is a 2 foot lift on 4 axle stands pretty stable? Is there anything that can be used as a backup? Thinking about it I have a set of four wheels that I can put under the sills, then if it does drop there would still be room for my head.
907
posted on 29/3/17 at 08:33 AM Reply With Quote
I made these that fit under the body or the wheels and lift to 500mm:-
Paul G
And with a car on:-
Or a more interesting car:-
The one and only member of the Suttol Owners Club. Now also the MX5 Owners Club.
Toprivetguns
posted on 29/3/17 at 09:09 AM Reply With Quote
http://www.locostbuilders.co.uk/forum/34/viewthread.php?tid=208167
Only drive as fast as your angel can fly... !
stevebubs
posted on 29/3/17 at 11:10 AM Reply With Quote
Paul G
And with a car on:-
I'm sure you can get them cheaper but.. http://www.cjautosheywood.co.uk/hyramp.shtml
Mr Whippy
posted on 29/3/17 at 12:02 PM Reply With Quote
tbh if it's all four wheels I just use large concrete blocks stacked 2 -3 high with wood spacers protecting the car, primitive but doesn't break, snap or tip over either. If it's just 2 wheels I'll just drive up double height ramps.
Want to build a pit some time in the garage when there isn't a car in the way...
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
posted on 29/3/17 at 01:47 PM Reply With Quote
Trolley jack and axle stands does it for me. Had most cars I've owned on them without an issue. I do have small strips of wood between the top of the stands and the car to protect the underside of the car.
spiderman
posted on 29/3/17 at 04:56 PM Reply With Quote
I used spare wheels to get mine at a reasonable height, see picture on left, stable and cheap, keeps spare wheel out of the way. I used a trolley jack to get them to that height, used a scissor jack to get the trolley jack underneath, must get myself a low profile jack.
Spider
New Topic New Reply
