Author: Subject: Turbo to Engine Pipework
posted on 29/3/17 at 07:54 PM Reply With Quote
Another daft question...
I can understand why a naturally aspirated engine might benefit from a larger-bore intake system and throttle body, but why do turbo engine tuners also like to use larger-bore pipes / throttle bodies, etc. ?
Most turbo-charger outlets that I've seen are fairly small in diameter. They also have to push the air through restrictions such as a MAF (if fitted) and a cooler. So why would wider pipework between the turbo / MAF / cooler / throttle body (and a wider TB itself) be advantageous?
Clearly there's an obvious answer here as it seem's the norm, but I can't understand why it wouldn't just lead to 'lag' and slow the air... ???
It's Evolution Baby!
JAG
posted on 30/3/17 at 08:47 AM Reply With Quote
You're mixing two attributes of the air intake system; air flow speed and air flow resistance.
Large bore pipes will definitely reduce the flow speed (increased lag) but if they also reduce the flow resistance then it may still be worth doing.
Justin
theduck
posted on 30/3/17 at 11:21 AM Reply With Quote
My understanding, which could be completely wrong, is you want to keep the pipework between the turbo and intercooler small and then the intercooler to inlet larger. I have no idea why or where that came from though I must have read it somewhere.
posted on 30/3/17 at 05:14 PM Reply With Quote
Cheers guys.
mark chandler
posted on 30/3/17 at 05:39 PM Reply With Quote
It's about balancing loss through friction with response, suck water up through a straw 6" long, then cut it down to 1" and it all gets easier, double the diameter of the Straw and it gets easier but not as responsive.
You do not want to be compressing a large volume when it's not doing anything sat in pipework.
