Author: Subject: Best place to buy sierra driveshafts?
Toprivetguns
posted on 30/3/17 at 05:01 PM Reply With Quote
My passenger side driveshaft has finally given up (bean can split) and its probably better to buy a new unit then repair from a cost point of few.
Its 795mm long with 28T outer and 26T inner. I've found a few websites, however not being sure of the exact specs of the donor I cant spec the correct shaft. I've looked on super 7th heaven, but still none the wiser.
Any help is always appreciated.
Only drive as fast as your angel can fly... !
posted on 31/3/17 at 08:23 AM Reply With Quote
I refurbished my donor Sierra driveshafts. A few years ago, but you could buy a kit of parts to do it, which included a new metal can. You have to peen the end of the metal can close over the CV joint, but it held perfectly well and never leaked. IIRC the kit was £15-20 from my local Ford main dealer. The job took me a couple of hours per driveshaft. You'll need a vice to hold it while you work on it.
[Edited on 31/3/17 by nick205]
Toprivetguns
posted on 31/3/17 at 08:38 AM Reply With Quote
Thanks Nick. I'm always keen to DIY, however trying to find these parts is now becoming a challenge.
ian locostzx9rc2
posted on 31/3/17 at 08:40 AM Reply With Quote
Most decent motor factors should be able to exchange them or get them refurbished for you .
posted on 31/3/17 at 10:01 AM Reply With Quote
Speak to your local Ford dealer. The spares counter guy in mine was a real gem and helped out no end. He even asked me to take the finished car in for him to see - which I did.
