Author: Subject: 6mm bore 5mm thread rosejoint
CRAIGR
Contributor
Posts 2750
Registered 30/8/05
Location Sussex
Member Is Online
Photo Archive Go!
posted on 1/4/17 at 11:15 AM Reply With Quote
Hi all
Looking for the above any pointers.
Can only find 5mm bore 5mmthread
gremlin1234
posted on 1/4/17 at 11:30 AM Reply With Quote
thread from april 2009 (exactly 8 years ago!)
http://www.locostbuilders.co.uk/viewthread.php?tid=110188
Slimy38
posted on 1/4/17 at 01:26 PM Reply With Quote
Buy a 6mm bore/thread rose joint, and an M5 helicoil to reduce the thread?
CRAIGR
Contributor
Posts 2750
Registered 30/8/05
Location Sussex
Member Is Online
Photo Archive Go!
posted on 1/4/17 at 01:29 PM Reply With Quote
Good call .Where can I get a 5-6 helicoil
Slimy38
posted on 1/4/17 at 01:44 PM Reply With Quote
I think this is what you need?
eBay Item
Although I'm not sure whether the helicoil size is the 'before' or 'after', so you might need the M5 version.
[Edited on 1/4/17 by Slimy38]
posted on 2/4/17 at 09:30 PM Reply With Quote
The OD of a helicoil is a special size, not simply the next size up metric thread.
bigwill64
posted on 3/4/17 at 08:21 PM Reply With Quote
why do they have to be 6mm bore 5mm thread?
CRAIGR
Contributor
Posts 2750
Registered 30/8/05
Location Sussex
Member Is Online
Photo Archive Go!
posted on 3/4/17 at 08:39 PM Reply With Quote
Gear change cable is a 5mm thread and gear-lever has a welded on 6mm mount
Interested in your shock mounts possibly
