Author: Subject: Edges on top harness mounts
Joshy
posted on 2/4/17 at 02:21 PM Reply With Quote
Hi all,
Below is a photo of my top harness mounts. Everything is contactable by a 100mm sphere (except the underside edge of the welded-in brace plates) - so I'm guessing the whole lot needs to have a radius => 2.5mm? Including the bolt heads?
And the harness holes in the seat too, correct?
Thanks!
Josh
Toprivetguns
posted on 2/4/17 at 03:57 PM Reply With Quote
Rubber U-trim and bolt covers wil do the trick.
Only drive as fast as your angel can fly... !
sdh2903
posted on 2/4/17 at 05:00 PM Reply With Quote
This is what Westfield sell/use.
I had some knocked up in some black vinyl at a local trimmers for a tenner.
posted on 3/4/17 at 10:15 AM Reply With Quote
That's what I did and the SVA man was satisfied.
