Author: Subject: Sierra Diff Mount
the_big_1
posted on 7/4/17 at 06:42 AM Reply With Quote
Sierra Diff Mount
Hi Guys,
About to weld new plates where the diff bolts too. I have made two new ones for my build as I am using the wider sierra diff 7.5 one. The original plates wouldn't have been butt up to the up rights so made new ones wider.
Question is, have you all used the same hole positions for the vertical diff height? i.e if I use the same hole positions as supplied with the kit only wider apart but height the same?
Or is there a measurement from say the centre of the prop-shaft flange to somewhere I could measure and maintain?
mcerd1
posted on 7/4/17 at 08:07 AM Reply With Quote
Not sure about your specific chassis, but the old dax rush I've got was built to accept both 7" and 7.5" diffs using the same mounts (with small spacers for the 7.5" and bigger ones for the 7" )
the_big_1
posted on 7/4/17 at 08:42 AM Reply With Quote
Hi ya,
Mine is the Haynes TMXR chassis.
cheers,
Carl
