Author: Subject: Alfa GT stiff clutch.
joneh
posted on 8/4/17 at 08:00 AM Reply With Quote
Hi All,
Any suggestions on my mstes Alfa GT JTDM 1.9 - it has a very heavy clutch pedal? Been like it for 3 years, from 30k miles so don't think it needs a new clutch.
Most garages seem to want to fit a new clutch. Forums suggest it seems to be a sticking release bearing or clutch fork getting stuck in bushes.
Thanks!
Jon
posted on 8/4/17 at 09:44 AM Reply With Quote
Is it worth taking the box out to sort the heavy clutch without replacing the clutch? If it was mine I would fit new!
ian locostzx9rc2
posted on 8/4/17 at 11:21 AM Reply With Quote
As said remove gearbox make sure it's all free and replace the clutch
joneh
posted on 8/4/17 at 11:34 AM Reply With Quote
Yeah I see your points, looking at the forums some suggest you can grease it without removing the box. Just wondered if anyone had any tips or a similar issue.
perksy
posted on 8/4/17 at 12:38 PM Reply With Quote
Is it cable or hydraulic actuation?
joneh
posted on 9/4/17 at 10:51 AM Reply With Quote
I'll check with him... I assumed cable.
joneh
posted on 10/4/17 at 08:12 PM Reply With Quote
Ok it's hydraulic....
posted on 11/4/17 at 07:19 AM Reply With Quote
If it has an external slave and visible linkage it may be possible to lubricate any visible linkage but if that doesn't work
then it's likely to be box out
