Author: Subject: Steering lock ignition problem
agors
posted on 10/4/17 at 08:53 PM Reply With Quote
Hi all,
I have a problem with mi ignition switch that is broken.
The issue is that I don't know where the steering lock comes from.
Do you have any idea? Could you help?
I would like to buy a replacement and fix my westfield
image uploader
gremlin1234
posted on 10/4/17 at 09:13 PM Reply With Quote
it looks like a layland cars (austin/morris/etc) part.
which bit is broken? if its the electrical part, then usually this can be replaced on its own. (though I do notice a jubilee clip round the barrel)
also does it have any part numbers on it?
agors
posted on 10/4/17 at 09:24 PM Reply With Quote
No, unfortunately no part number;
Searching on internet it could be a LDV convoy part, but not sure;
The only part broken is the electrical switch
gremlin1234
posted on 10/4/17 at 09:49 PM Reply With Quote
as I say, the electrical switch is usually an insert.
quick searching found some, - though they seem very expensive
try this for a start
holden.co.uk
or
Lucas 157SA Ignition Switch 39415 / 579085 for Triumph TR6 GT6 Stag & Land Rover
can you show a photo of the broken bit, ie the connectors etc.
edit, make holden link work
[Edited on 11/4/17 by gremlin1234]
Chris Ridgers
posted on 11/4/17 at 10:40 AM Reply With Quote
To my eyes it looks like the old style defender ignition barrel.
Charlie_Zetec
posted on 11/4/17 at 11:06 AM Reply With Quote
Not 100% sure on this, as Defenders usually have an angled barrel from the lock. Could possibly be from an early 90 (before they called them Defenders) or a Series though? If it is, then I definitely didn't pay £37 for a replacement electrical unit on the back of it, think it was nearer £18-20!
Chris Ridgers
posted on 11/4/17 at 11:13 AM Reply With Quote
Yeah, hard to tell from picture! like I said looks like the old defenders (series) could be wrong but just my 2p.
Lucas sell the replacement switch for them.
Good luck
gremlin1234
posted on 11/4/17 at 12:05 PM Reply With Quote
this page has pictures of some of the different locks
really need to see the wiring side of the broken one
http://stores.ebay.co.uk/Auto-Electrical-Spares/ignition-switches-/_i.html?_fsub=273592016&_sid=117015556&_trksid=p4634.c0.m322
agors
posted on 11/4/17 at 09:09 PM Reply With Quote
Unfortunately I don't have now another pic.
The defender one seems very similar, but the barrel looks different in the diameter that connect to the column.
I'm buying a replacement for 10£ for the LDV,
If it doesn't work, il try with the defender one
agors
posted on 15/4/17 at 07:37 PM Reply With Quote
image upload
agors
posted on 24/4/17 at 07:05 PM Reply With Quote
Just to close the topic,
I used a replacement part from and LDV and it's fixed
gremlin1234
posted on 24/4/17 at 07:23 PM Reply With Quote
good that its fixed!,
did you replace the complete mechanism, or just the electrical switch part?
edit sp...
[Edited on 24/4/17 by gremlin1234]
agors
posted on 24/4/17 at 07:52 PM Reply With Quote
Just the electrical part,
If I'll find a defender ign switch I'll try to see if it fit
