Author: Subject: Stuck alloy
joneh
posted on 15/4/17 at 07:49 PM Reply With Quote
Stuck alloy
Jeep woe #997
My rear wheel has corroded itself to the hub.
Is the general method of removal spray with penetrating fluid then lump the life out of it with a lump hammer? I have a nail in my tyre. Thanks Toolstation.
Jon
Hodor
posted on 15/4/17 at 07:52 PM Reply With Quote
Loosen nuts just enough and drive a few feet back and forth. Hopefully should do it.
spiderman
posted on 16/4/17 at 04:14 PM Reply With Quote
Might require a bump up and down a curb or a very tight turn with a little power on to get it to let go. They can release with a rather loud noise
Spider
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 16/4/17 at 05:12 PM Reply With Quote
Block of wood and hammer . Give it a hit rotate hit it again rotate and so on .
Adamirish
posted on 17/4/17 at 12:07 AM Reply With Quote
This.
I had this with a non mini mini. Just loosened the nuts and dropped it down (hard) off the jack. That did it.
MK Indy 1700 Xflow
907
posted on 17/4/17 at 05:54 AM Reply With Quote
Rear wheel, Passat estate.
Loosen nuts. Drop down off jack. Rock car sideways.
Paul G
Mr Whippy
posted on 17/4/17 at 12:12 PM Reply With Quote
obviously well serviced brakes on that car...
joneh
posted on 17/4/17 at 12:25 PM Reply With Quote
It's my car! Brakes are fine and looked after. The wheel was off last service (by me).
It came off with a few kicks.
posted on 17/4/17 at 02:05 PM Reply With Quote
I keep a lead mallet in my toolbox for knocking off alloys, it's the type used for spoked wheels on MGs etc
