Author: Subject: Zetec fuel pressure regulators
cliftyhanger
posted on 21/4/17 at 11:37 AM Reply With Quote
Just checking my st170 install in my spitfire before plugging the ecu in.
Turns out the golf pump I have fitted in the fuel tank is pushing out about 3.5bar, but the blacktop fuel rail has a regulator fitted rated at 3.8bar, so will not open. Means the pump will burn out I reckon.
If there a pressure regulator that will bolt on the fuel rail and rated at 3bar?? Or do I need to get an aftermarket type?
Pointers appreciated. Pressing on with the checking process, and the engine should fire when we get that far, but will only run for a short time until the FPR issue is sorted. (and I can't change the fuel pump, unless there is a straight swap available)
Clive
HowardB
posted on 21/4/17 at 12:02 PM Reply With Quote
will the 3bar reg from a silver top fuel rail drop in?
Howard
cliftyhanger
posted on 21/4/17 at 12:53 PM Reply With Quote
Not sure, will find some pics...
is it deffo 3 bar?
HowardB
posted on 21/4/17 at 01:09 PM Reply With Quote
mine is and I may have a spare,.
Just a thought,...
Has the golf pump got a built in regulator and so is running as it should, or is it that the pump is faulty?
I had in my mind that petrol injector pumps run at circa 10bar
hth
Howard
silky16v
posted on 21/4/17 at 02:59 PM Reply With Quote
shouldn't be using an low pressure intank pump on the ST170 Duratec
soon as revs rise you will drop fuel pressure, fit a proper aftermarket Bosch external inline pump
cliftyhanger
posted on 21/4/17 at 04:25 PM Reply With Quote
Samepump seems to be supplied to all tehgolfs including the turbos, so should be adequate. I will see if there is a better version.
