Author: Subject: Bottom dash area & exemption?
furryeggs
posted on 21/4/17 at 12:29 PM Reply With Quote
This is my dash, From the passenger side of the dash to the steering wheel I have a19mm radius, but the other side of the steering wheel has a cut out for the ignition which doesn't have a 19mm radius. This area does fall under the exemption area measured from the steering wheel so does it need a 19mm radius as well?
I'm about to drill and mount the dash but would rather be sure before fixing it in place, if it needs modifying I'd rather do it now.
[img][/img]
Thanks guys
pekwah1
posted on 21/4/17 at 12:35 PM Reply With Quote
I would just stick some edging strip over the part without a return, seems to be the simplest solution if you are in any doubt.
loggyboy
posted on 21/4/17 at 01:04 PM Reply With Quote
The instrument panel lower edge within the “specified zone” must have a radius of curvature not less than 19mm or 5mm and be covered with a non-rigid material, except where an adaptation for a disabled person makes it impossible to comply. (see Notes 6 and 7)
and the area to the right of the wheel to the door in exepmted from the specified zone:
Mistral Motorsport
