Author: Subject: Recommend a car tyre pressure guage
posted on 28/4/17 at 08:01 AM Reply With Quote
Morning all,
I've been checking (and inflating when necessary) SWMBO's car tyres using my bicycle track pump. Suggested pressures are between 2.3 and 3.0 bar for light and heavy loads. This is working OK, but I'm hoping one of you can recommend a tyre pressure guage in the sub £10 price range. I'm also not averse to a foot pump with a guage either to make tyre inflation easier.
Thanks,
Nick
cliftyhanger
posted on 28/4/17 at 08:08 AM Reply With Quote
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xsykes+tyre+pressure+gauge.TRS0&_nkw=sykes+tyre+pressure+ga uge&_sacat=0
Had one for years. Decent quality and easy to use.
I think it is accurate, but other gauges are always within a couple of psi, some more, some less. Not sure how to check calibration on a pressure gauge.
peter030371
posted on 28/4/17 at 09:07 AM Reply With Quote
Manual tyre pressure gauges are known to 'drift' if knocked about to much. As such I would only ever go for a better quality digital gauge as the manual ones could arrive in the post 'knocked about' and thus in-accurate from day one even if you look after it
You can get gauges checked very easily but it will cost £50-£100 a go
gremlin1234
posted on 28/4/17 at 10:04 AM Reply With Quote
some of the tiny electric compressors have a digital gauge, and can be set to pump up to a pre-set pressure
ie
http://www.halfords.com/workshop-tools/garage-equipment/tyre-inflators-pressure-gauges/halfords-digital-tyre-inflator
there are cheaper ones too
gremlin1234
posted on 28/4/17 at 07:30 PM Reply With Quote
see also, this current thread
https://www.locostbuilders.co.uk/viewthread.php?tid=208681
posted on 29/4/17 at 08:18 AM Reply With Quote
"Digital" does not mean "Accurate"; some of the cheap digital gauges can be very inaccurate right out of the box.
motivforz
posted on 29/4/17 at 10:05 AM Reply With Quote
I've got two mechanical tyre pressure gauges that read within 1psi of each other, and compare within 3psi of an old footpump.
My bicycle pump however underreads by around 20psi! So that's never used for measuring, only inflating.
peter030371
posted on 29/4/17 at 11:54 AM Reply With Quote
Which is why I said a quality gauge
posted on 2/5/17 at 12:02 PM Reply With Quote
Thank you chaps, I'll take a look at the suggestions.
