Author: Subject: Steering Shaft Welding etc.
the_big_1
posted on 2/5/17 at 06:39 AM Reply With Quote
Hi Guys,
I want to make an extension to a steering shaft using the following two parts.
https://www.extremebajakarts.co.uk/collections/steering-parts/products/latest-rage-5-8-inch-x-36-spline-coupler
https://www.extremebajakarts.co.uk/collections/steering-parts/products/6-inch-long-by-5-8ths-inch-x-36-splined-steel-stub-shaft
What method would you guys use to connect them as well as the welding?
Mash
posted on 2/5/17 at 06:51 AM Reply With Quote
Piece of steel tube 5/8" id over the join?
the_big_1
posted on 2/5/17 at 06:55 AM Reply With Quote
Nopmal that's what I do but its a small adaptor to go on the end of the shaft.
Nickp
posted on 2/5/17 at 08:24 AM Reply With Quote
Yeah, thick walled stuff. If it's for the IVA then you should drill and fit a roll pin in each joint too.
the_big_1
posted on 2/5/17 at 08:38 AM Reply With Quote
I don't think it would fit. The adaptor loos a lot bigger than 5/8"???
Yeah, I have used roll pins on all of them so far.
rf900rush
posted on 2/5/17 at 12:58 PM Reply With Quote
When I built my Dax Rush the Sierra Steering column needed extending.
Dax would not sell the Parts. I believe a customer welded their own with a very serious out come.
They would only weld them to my own steering and then serial numbered it.
Be very careful.
the_big_1
posted on 2/5/17 at 01:02 PM Reply With Quote
Hi ya,
All the steering on Haynes has to be welded at some point and all the parts available.
On the two shafts I have made so far have been connected with tube with shaft inside, puddle welded in lots of places, then a roll pin in each end.
mcerd1
posted on 2/5/17 at 01:29 PM Reply With Quote
Be very careful.
^^ what he said - although that was due to the customer using inappropriate welding wire / rods
if its for a ford column with the triangular section then a few places sell steeing UJ's that fit this (inc. CBS) no welding required
the_big_1
posted on 2/5/17 at 01:33 PM Reply With Quote
Its not a Ford one and I need to extend the shaft by say 100mm. So have a splined socket and a splined shaft requiring connecting together.
