Author: Subject: sierra hubs
patrick
posted on 3/5/17 at 06:16 PM Reply With Quote
sierra hubs
hello,
sorry but I usually don't write in English so I 'll make a few mistakes
I'm building a kitcar from scrap, donor car is a ford sierra, I want to know wich ball gearing I've to use to put the sierra hubs on the chassis
thanks allready
regards patrick
posted on 3/5/17 at 06:45 PM Reply With Quote
Hi Patrick,
Do you mean the front hub or the back hub.
If you have any photographs it will help people see what you need.
patrick
posted on 3/5/17 at 06:51 PM Reply With Quote
I mean the front hubs, the back is no problem, I want to know from wich car I've to order
mcerd1
posted on 3/5/17 at 07:12 PM Reply With Quote
see here:
http://www.burtonpower.com/parts-by-fitment-type/parts-by-car-model-ford/ford-sierra.html?product_area=598&product_group=345
there are only 3 types of front wheel bearings - ordinary sierra, 4x4 or cossie 2wd
these are the normal ones:
http://www.burtonpower.com/wheel-bearing-kit-front-ford-sierra-not-cosworth-not-4wd-brt988.html
[Edited on 3/5/2017 by mcerd1]
bonzoronnie
posted on 3/5/17 at 07:37 PM Reply With Quote
Hi Patrick
Perhaps you asking how to attach the Sierra hub to the lower wishbone. ?
You will need to get a ball joint from an Austin Maxi.
The Sierra hub will need to be reamed to accept the taper of the Austin Maxi ball joint.
Hope that is of some help.
patrick
posted on 3/5/17 at 08:21 PM Reply With Quote
thanks that was my question
bonzoronnie
posted on 4/5/17 at 07:11 PM Reply With Quote
Hi Patrick
Gave this some more thought.
Assuming you are going for a Haynes type build, you will need Ford Transit Drag links to attach the top wishbones.
Drag links you need are right hand thread & M14 , 1.5mm thread pitch if memory serves me right.
You will also need to make or buy adapters to fit in the top of the Sierra hubs, these fit where the suspension strut would normally fit.
These are commonly know as mushroom adapters.
On the Haynes roadster, the tapered hole in the adapter is offset.
patrick
posted on 4/5/17 at 09:05 PM Reply With Quote
thanks now I know a lot more
