Author: Subject: BEC suspension setup
olimarler
posted on 4/5/17 at 05:18 PM Reply With Quote
Hi all,
I'm about to start my setup on my locost Honda CBR kit.
Anyone help with what geometry I should be aiming at?
Oli
Matt21
posted on 4/5/17 at 08:02 PM Reply With Quote
I'm not sure if it would be the same, but on my Indy I go for;
Ride height:
Front - low as possible
Rear - 10-15mm higher than front
Camber:
Front - 2deg negetive
Rear - 0.75deg neg
Toe:
Front - 0.5mm in
Rear - (not adjustable) 1mm in
Caster:
Not adjustable -
Corner weights:
Still playing about with these, though it was set up previously to have equal weights on the front wheels
Instagram: @matt211988
Photobucket
My YouTube
olimarler
posted on 4/5/17 at 10:26 PM Reply With Quote
That's perfect!
Mine is based on an Indy so happy days
Matt21
posted on 5/5/17 at 04:09 AM Reply With Quote
You may want to go for 1.5deg camber on the front if it's just for road use.
I find with mine that one turn of the top mount on the upright gives me about 0.5deg, so I just adjust it accordingly.
Photobucket
My YouTube
CosKev3
posted on 5/5/17 at 06:08 AM Reply With Quote
How's your sump clearance?
With a BEC this can be the deciding factor in front ride height.
I had 100mm on mine,but could get it to bottom out quite easily on dips in the road,and also cats eyes on occasions
