40inches
posted on 6/5/17 at 04:06 PM |
Engine oil temperature low?
Is this going to be a problem?
The jag engine runs at around 53-55 degrees when cruising, and up to 68degrees when pushing on.
I have verified the temp with another thermometer.
ian locostzx9rc2
posted on 6/5/17 at 06:06 PM |
That's is very low you need to be at 80 plus degrees ideally .
CosKev3
posted on 6/5/17 at 08:27 PM |
Yeah as above,it's not hot enough to evaporate any moisture that's in the oil/crank case.
So will result in some nice Mayo in the cam cover etc
sdh2903
posted on 6/5/17 at 08:47 PM |
I had this on an st220 (same engine?). My heart sank when I found the cap full of gunk. Was purely down to the car being used for 5-6 mile commutes
and oil not getting hot enough. Seems unusually low that? Are you using an oil cooler that you could delete to see what the temps do?
40inches
posted on 6/5/17 at 08:53 PM |
Similar crankcase as the ST220, I removed the oil cooler, that may be the problem. I may have to find a way to refit it
sdh2903
posted on 6/5/17 at 09:04 PM |
Is it a water/oil heat exchanger type?
40inches
posted on 6/5/17 at 10:43 PM |
That's the one. Standard fitting, but I had to remove it to get the engine in the MK. Doh!
sdh2903
posted on 7/5/17 at 06:39 PM |
Could you slave it back in remotely to see the effect it has on the oil temps?
CosKev3
posted on 7/5/17 at 09:02 PM |
The modine helps get the oil up to temp as well as cooling it once the oil gets hotter than the coolant.
It balances the temps of the engine
CosKev3
posted on 7/5/17 at 09:04 PM |
I've had a few people ask me to look at there cars when garages have told them the head gasket has gone,to find out they never use the car for
it to get hot enough to evaporate the moisture in the oil/crank case!
