Slater
posted on 6/5/17 at 04:19 PM |
Zetec Temp and Oil Pressure Question
Hi I have a silvertop 1.8 zetec with 5/30 semi synth oil. The normal engine temperature when driving is 80 Deg C (sensor is in the thermosat housing)
and oil pressure remains at about 80 psi.
Is this normal temp/pressure for the zetec? If not, do I need to do anything about it? I am wondering if the temperature is too low I could block of
part of the radiator?
posted on 7/5/17 at 10:59 AM |
That sounds good there, nothing to worry about.
Slater
posted on 7/5/17 at 12:09 PM |
OK, thanks for the reply Coozer.
