Author: Subject: Progress towards IVA
mikeb
posted on 8/5/17 at 08:26 AM Reply With Quote
Just thought I'd share a pic of my haynes.
Not a million miles away now
20170507_1 23250 by mjb22001, on Flickr
[Edited on 8/5/17 by mikeb]
Slimy38
posted on 8/5/17 at 08:39 AM Reply With Quote
Very nice! Those headlights seem very tucked into the bonnet, is it an optical illusion of the photo? It almost looks like there will be a dark spot dead centre.
mikeb
posted on 8/5/17 at 09:00 AM Reply With Quote
They are quite low, but no dead spot, I have some spacers to lift them up about 30mm for IVA
davidimurray
posted on 8/5/17 at 09:49 AM Reply With Quote
Are those repeaters on the rear wings? Check them very carefully as there is a max distance from the front of the car. My inspector got quite picky with them. luckily is was in by 10mm!!
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Nickp
posted on 8/5/17 at 10:42 AM Reply With Quote
Look very similar to mine, should be OK, just
mikeb
posted on 8/5/17 at 11:16 AM Reply With Quote
Think they are ok (just)
Depends where they measure from. they are just within from the nose cone. From leading edge of front tyre no problem. wasn't sure where they measure from.
davidimurray
posted on 8/5/17 at 11:34 AM Reply With Quote
When he measured mine he put a set square against the most forward point on the car (nose cone on mine) and then measured back from that.
