dwebber597
posted on 10/5/17 at 09:55 PM |
TMXR pedal box suggestions
Hi all
I'm looking for a pedal box for my TMXR chassis. I bought the Obp kit only to find its too wide to fit on the bottom rail.
Soooo I'm now looking for a smaller alternative.
Thanks in advance
ste
posted on 10/5/17 at 10:18 PM |
I have a Haynes roadster spec pedal box with mx5 clutch and brake cylinders for sale. I'm wanting £100 for it all posted
u2u me your dimensions and i'll measure it tomorrow
[Edited on 10/5/17 by ste]
dwebber597
posted on 11/5/17 at 07:01 AM |
Thanks ste. I'll get the measurements over to you shortly.
voucht
posted on 11/5/17 at 11:41 AM |
Are you willing to DIY, or are you looking exclusively to already made pedal box?
If you are willing to DIY, here is the Haynes Roadster pedal box I redesigned to use square section tubes as pedal shafts instead of 3 and 5mm
plates.
My blog post 1
My blog post 2
Link to the Pedalbox construction guide (PDF) I made for my
fellow builders (in English)
You just have to adapt the clutch pedal as my pedal box is designed for a cable clutch, but you just make a second brake pedal with the same length as
the clutch pedal.
Hope that can help
555
miskit
posted on 11/5/17 at 05:02 PM |
Fantastic pfd!
dwebber597
posted on 11/5/17 at 07:46 PM |
Thanks.... Thats one hell of a good pdf.
The standard haynes box is gonna be to wide for my chassis.
Im gonna use talons, less thinking and i can concentrate on the wiring while i wait for it to be delivered
