Author: Subject: Floppy pedals
Matt21
posted on 11/5/17 at 04:46 PM Reply With Quote
Floppy pedals
I'm having a bit of an issue with my pedals lately, I haven't noticed it before but now it is really bugging me.
Mainly the throttle pedal, when I'm not on it the pedal flops forward which puts it 2inchs+ in front of the brake, which is really annoying when you're trying to get back on it!
The clutch is doing it slightly too, but not as bad.
Throttle is the same as this,
It has a small spring at the bottom which helps pull the throttle off, but there is nother stopping the pedal falling forwards.
Am I missing something obvious or how do people stop this happening?
Instagram: @matt211988
Photobucket
My YouTube
Bluemoon
posted on 11/5/17 at 05:24 PM Reply With Quote
L shaped bit of metal under the pivot bolt to act as a forward stop. At least that is what I did simple and seems to work well.
jacko
posted on 11/5/17 at 05:39 PM Reply With Quote
same here a L shape bracket
Matt21
posted on 11/5/17 at 05:41 PM Reply With Quote
So it would be bolted in with the pivot bolt? then you just adjust the position of it to set the stop?
Photobucket
My YouTube
Banana
posted on 11/5/17 at 05:50 PM Reply With Quote
Mine has a m6 bolt behind the lower half, which acts a stop. I put a large sleeve around it, which in turn moved the pedal back.
I needed to do that as i kept hitting the throttle as i was jumping on the brake.
Bluemoon
posted on 11/5/17 at 10:11 PM Reply With Quote
Yes rotate to suite then nip the bolt..
40inches
posted on 12/5/17 at 08:56 AM Reply With Quote
I used ally angle, but bent steel strip is as good.
Banana
posted on 15/5/17 at 06:30 PM Reply With Quote
How do you find the heel rest you fitted? Is there anything you would change? As im about to fit one.
spiderman
posted on 15/5/17 at 10:59 PM Reply With Quote
I've used lightweight pull springs to pull them back towards the bulkhead, as some manufacturers do, took mine from the donor car, also takes up any slack in cables and linkages.
Spider
