Author: Subject: Lightweight Zetec Flywheel
timdave25
posted on 12/5/17 at 03:11 PM Reply With Quote
I have is a late CVH EFI flywheel, they are just over 6 kg and have marks for crank sensor. The bolt pattern is the same as 1800/2000 zetec all you need to do is drill out to 11mm. You can use a 1.6/1.8 early mondeo clutch that will have the same splines as a type 9 Or have it drilled to take a pinto clutch. Ring gear is the same so re use starter.
A number of people have used them in sevens and other cars which use zetec engines so these flywheels are getting rare now.
I'm looking for £75 posted to UK mainland.
