<<  1    2  >>
Author: Subject: Pre-IVA checks please (Picture heavy)
tims31
posted on 12/5/17 at 03:14 PM Reply With Quote
Have had my paperwork approved and test is now booked for 16th June so I would like the usual cast over of my car please and comments on what you think may be a problem at IVA.
Build: http://www.martinsfurybuild.co.uk/
adithorp
posted on 12/5/17 at 03:29 PM Reply With Quote
Only looking on my phone but...
Looks good. Is that a combo reverse and fog light in the middle? If not you're missing g one or the other. Is it makes as a fog light (think its either an S or F on it)?
http://jpsc.org.uk/forum/
pekwah1
posted on 12/5/17 at 03:41 PM Reply With Quote
looks good, might be missing some nut covers (seat belt mounts and wing mirrors) but can't tell from the photos.
Are you sure that you've got the required visible angles for the side repeaters when behind the car?
tims31
posted on 12/5/17 at 03:46 PM Reply With Quote
Yes a combo fog/reverse light and it is F marked. Taken a gamble with the clear lens, the manual just says 'emits Red light' not a red lens
The side repeaters are visible from the rear but will double check the angles.
Nut covers are on the mirrors
Thanks, keep them coming
[Edited on 12/5/17 by tims31]
tims31
posted on 12/5/17 at 03:48 PM Reply With Quote
I do need some nut covers for the belt bolts but they are 7/16 bolts and the covers I have just fall off. Need to find some that fit
pekwah1
posted on 12/5/17 at 03:49 PM Reply With Quote
or just a bit of glue.....
tims31
posted on 12/5/17 at 04:06 PM Reply With Quote
Having looked at the quality of some of the pictures I have reposted them with better quality ones
pekwah1
posted on 12/5/17 at 04:18 PM Reply With Quote
is it sad that i knew that those were A539s from the tread pattern?
gremlin1234
posted on 12/5/17 at 04:55 PM Reply With Quote
looks good
a few things I noticed
the vin plate may have too much information/ incorrect format.
front brake flexy hoses seem far too long
does under the dash on the passenger side have sufficient curvature
steering column seems very close to the chassis, and appears almost straight, so not giving much effect for protective steering. also is it missing a lock nut on the joint above the uj?
miskit
posted on 12/5/17 at 05:38 PM Reply With Quote
Will the fire extinguisher and bracket pass the cockpit pointy bit test?
ReMan
posted on 12/5/17 at 08:05 PM Reply With Quote
nothing new and i think its a very nice car
as mentioned, side repeaters and steering chafing on chassis, brake pies ok as long as they don't contact anything lock to lock
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
tims31
posted on 12/5/17 at 08:31 PM Reply With Quote
Thanks for the input.
The steering column isn't touching the chassis but is close. The UJ does not have a lock nut and is as is from the Sierra but does have thread lock on the bolt. The column does slide into the outer so does offer protection.
The brake hoses are long but do not touch and chassis or wishbone and are long enough to flex for the steering angles. Supplied by Fury so hopefully OK.
Under the dash has fibreglass panels of 25mm radius covered in foam.
I guess I may have to remove the fire extinguisher
kingster996
posted on 12/5/17 at 09:52 PM Reply With Quote
Looks very tidy.
Difficult to see from pics but make sure seat belts don't pull down on harness slots. The anchorage points need to be level not below if you follow me.
Can't see the repeaters being an issue like they are on a "seven" style car.
Good luck!
[Edited on 12/5/17 by kingster996]
I used to be indecisive, but now I'm not so sure
HowardB
posted on 13/5/17 at 12:38 PM Reply With Quote
looks excellent, nothing further to add except good luck and hope to see you on the road soon
Howard
avagolen
posted on 13/5/17 at 05:09 PM Reply With Quote
Looking great. Best of luck.
I wrapped the nuts on my seatbelt mountings with insulating tape to help the nut covers stay on. No glue involved.
tims31
posted on 13/5/17 at 05:46 PM Reply With Quote
Thanks all, hopefully not too many issues. Will keep you updated.
Len, did you use the flexi brake hoses supplied by Fury?
gremlin1234
posted on 13/5/17 at 06:10 PM Reply With Quote
blu-tack or chewing gum would also work
avagolen
posted on 13/5/17 at 06:15 PM Reply With Quote
Yes. No problems with them at Yeading.
hellblue
posted on 13/5/17 at 08:00 PM Reply With Quote
Very hard to tell from the pictures but do you have the correct wheel arch tyre coverage at the rear ?
avagolen
posted on 13/5/17 at 08:26 PM Reply With Quote
Hi Martin,
I have uploaded a couple of pictures of my front flexible brake pipes. Hope these help.
big_wasa
posted on 13/5/17 at 08:44 PM Reply With Quote
Looks great.
Had a sneaky drive around the block yet ?
After Iva you will want to move the air filter.
posted on 14/5/17 at 08:19 AM Reply With Quote
Not sad, I recognised them too...familiarity I guess.
tims31
posted on 15/5/17 at 09:41 AM Reply With Quote
Hi Martin,
Thanks Len, Mine are pretty much the same. They don't touch anything lock to lock so hopefully should be ok.
Originally posted by big_wasa
Looks great.
Not driven around the block yet as its been raining but do plan to have a test drive if I can find somewhere locally and borrow a trailer just to bed the brakes in and test speedo etc and iron out any issues before the test on the 16th June.
The air filter is something I as going to look at post IVA. May have to make some sort of sheild around it so the hot air from the rad goes underneath and force cool air onto it. I'll drop your bead tool off when I'm on the road wasa so you can have a proper look.
tims31
posted on 15/5/17 at 09:44 AM Reply With Quote
Hope they should be ok, they don't stick out past the top of the arch if thats what you mean?
posted on 15/5/17 at 10:10 AM Reply With Quote
My SVA inspector told me that if he looks straight down from the arch and can't see rubber then it's obviously OK. If he can see the wall of the tyre then he will look a lot closer, probably using a straight edge and rule to check how far it sticks out - in other words, questionable and needs investigation. If he can see tread the it definitely fails! Other testers may have different ideas.
As far as I can see in the photos, I'd say that you're well covered.
<<  1    2  >>
