Author: Subject: Is she filthy?
Christof
posted on 15/5/17 at 03:21 PM Reply With Quote
Is she filthy?
Just needed to get your attention
Took my Sylva Striker Crossflow Weber40s out for a shakedown and it would get to around 2,500-3000 and would struggle to accelerate beyond just a light open throttle. Would rumble and judder. On a light throttle it would rev all the way up to max, but only very slowly. Generally not much performance.
Suspicion is old fuel (4-5 months old) and dirt/rust in fuel system - is this dirty enough to cause an issue - pics below?
I'd like to change the tank for the ss version (classic mini van) but would need to modify the neck and add a vent - job for another day.
Let me know what you think.
https://www.dropbox.com/s/0k657m5ncqua9ai/039%20%28Medium%29.JPG?raw=1
https://www.dropbox.com/s/mgk2k7q10t6xrxu/042%20%28Medium%29.JPG?raw=1
[Edited on 15/5/17 by Christof]
ian locostzx9rc2
posted on 15/5/17 at 03:45 PM Reply With Quote
That will do it
Nickp
posted on 15/5/17 at 04:01 PM Reply With Quote
Yep, proper filth!!
Christof
posted on 15/5/17 at 04:20 PM Reply With Quote
Is this likely to cause me any carb issues? Suppose I'll find out.
bi22le
posted on 15/5/17 at 07:03 PM Reply With Quote
This just cracked me up. Have you seen fresh fuel?!?
Thats dirty even for oil!
Joking aside, that crud is from your tank. I am currently using fuel that is almost a year old. Granted it was in an air tight jerry can but its working fine.
Please read my ring story:
Christof
posted on 16/5/17 at 08:46 AM Reply With Quote
Glad you enjoyed the filth
Whipped off the fuel tank, looking rather crusty inside (pics below) but it's probably 40+ years old. Don't fancy trying to revive it, so will buy a stainless steel one and modify to suit.
I'll have to cut/rotate/weld the filler neck, that should be ok, but how do people recommend that I add a breather - at the moment there is a thin copper type pipe coming out that I assume was welded(?) or brazed in. It is attached to a short piece of hose with a valve with OUT> pointing towards tank, so assume its vacuum release and not pressure release, which isn't quite right for IVA man.
Think I'll weld in a SS hose union and buy a fancy two way valve.
Crusty
pond life
neck modifications
breather close up
