Author: Subject: new fuel pump, denso coil and magnetronic ignition
Pat_T
posted on 17/5/17 at 08:04 PM Reply With Quote
The clearout continues!
1x 130lph high pressure fuel pump (Bosch style) - used for about 50 miles on my old 190bhp 2.0L Vauxhall redtop Seven before I changed to a new fuel tank with integral pump. Comes with a rather fetching lightweight anodised purple aluminium bracket and rubber sleeve which is brand new and has never been fitted. £20 posted
1x Denso plugtop coil - as used on Honda's, GSXRs, Triumphs and several other bike engines I believe. I've taken a photo of the part number so you can cross reference for your application. Brand New. £12 posted
1x Lumenition Magnetronic ignition system - this was (is?) designed for classic mini to replace the contact breakers and condensors on the vacuum distributor in the quest for more reliable spark. I believe they are a highly thought of mod for A-series engines. New and never used (but purchased in around 2004!) £10 posted
cheers,
Pat
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 17/5/17 at 08:30 PM Reply With Quote
Pump please
lsdweb
posted on 17/5/17 at 08:31 PM Reply With Quote
Hi Pat
I'll have the Magnetronic please.
Ta
Wyn
lsdweb
posted on 17/5/17 at 08:32 PM Reply With Quote
I'm interested in the books too so if you want to do a deal to save postage let me know.
Pat_T
posted on 17/5/17 at 08:40 PM Reply With Quote
Hi Wyn,
I can't end the books now as there's <24hrs on the auction. However if you win the auction that I'll chuck the magnatronic in for an extra £6 only as it saves me one less parcel to post! Sound fair?
Originally posted by lsdweb
Hi Pat
Ta
Wyn
lsdweb
posted on 17/5/17 at 08:57 PM Reply With Quote
Ok. Thanks.
I'll have a bid on the books!
Wyn
madrallysport
posted on 18/5/17 at 12:52 PM Reply With Quote
Can i have the 1x Lumenition Magnetronic ignition system - this was (is?) designed for classic mini to replace the contact breakers and condensors on the vacuum distributor in the quest for more reliable spark. I believe they are a highly thought of mod for A-series engines. New and never used (but purchased in around 2004!) £10 posted
I'll send you a pm now
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
Pat_T
posted on 19/5/17 at 10:32 AM Reply With Quote
only Denso Bike engine coil left now..
