S1502
posted on 18/5/17 at 02:49 PM |
Zetec thermostat
Hi guys,
This may have been covered a million times but just wondered if there is any difference in a silvertop themostat housing too a black top?
Have managed to snap the thin outlet and need too replace.
Is it a straightforward swap? What about the thermostat sensor and stat intself or will i need new ones?
Schrodinger
posted on 18/5/17 at 03:29 PM |
I think you will find that the blacktop housing is plastic and the sensors clip in whereas the silvertop I had, had an alloy housing with screw in
fittings.
Keith
S1502
posted on 18/5/17 at 03:41 PM |
Ok thats fine but the sensor would still presumably run on the old loom
big_wasa
posted on 18/5/17 at 04:21 PM |
The only Oem alloy housing was on the 1992 and 1993 Orion / Escort and are über rare.
The rest are all plastic. From a Mondeo to the Focus Rs.
There are differances though. The early ones are thicker plastic and better quality. The last of the focus housings are rubbish with thin plastic that
split and leak. Early ones had screw in sensors mid life they had push in sensors end of life they had no sensors as the coolant sensor was in the
head between exhaust ports 1 and 2.
S1502
posted on 18/5/17 at 04:39 PM |
So im guessing ebay is my best bet on a replacement
tims31
posted on 18/5/17 at 07:19 PM |
Just bought mine from here eBay Item
Have to drill and tap the thread though for the sensors, see my post
http://www.locostbuilders.co.uk/forum/9/viewthread.php?tid=208971
Build: http://www.martinsfurybuild.co.uk/
S1502
posted on 18/5/17 at 07:36 PM |
Did you find out the thread?
tims31
posted on 18/5/17 at 09:06 PM |
Waiting to hear, not long posted. I'll let you know.
