Author: Subject: More powerful direct fit replacement for 919 blade engine?
dmrider_10
posted on 18/5/17 at 08:42 PM Reply With Quote
Do the more powerful blade engines share the same engine mounting locations? Any others that would be a direct fit?
hobbsy
posted on 18/5/17 at 09:08 PM Reply With Quote
Another 919 blade with a turbo or rotrex fitted to it? Definitely the former has been done and probably the latter.
PAUL FISHER
posted on 18/5/17 at 09:24 PM Reply With Quote
I had the 929cc rry fireblade fitted in my Indy, the first of the fuel injected blade engines, the mountings are different to the 919cc, so not a straight swap.
Matt21
posted on 18/5/17 at 09:50 PM Reply With Quote
Nope.
I had a lot of parts to rotrex mine, turns out it's not so easy to do! or cheap! I got the full charger kit for £350 and it was still going to be expensive.
Best bet is a newer, better engine.
But then you'll need,
Engine, engine mounts, ecu, loom, tuning, exhaust, maybe prop shaft alterations, cooling pipes etc
So also works out expensive.
I came to the conclusion that I'd be better off stripping as much weight as possible and improving my driving and get the car set up right.
So far it has been successful and I can keep up/overtake most things on track.
Instagram: @matt211988
Photobucket
My YouTube
dmrider_10
posted on 19/5/17 at 08:31 AM Reply With Quote
Car is a fury and already weighs circa 470kg, theres nothing else to get rid of ha. Not much comes past us tbh this side of a radical/atoms etc thus we thought we could drop in soemthng else (if it was a straight swap) to get another 30 odd bhp. Not bothered enough (yet) to start making new engine mounts so we will just enjoy it as it is I think for now
sam919
posted on 19/5/17 at 02:40 PM Reply With Quote
My 919 fury had rear disc conversion and weighed 425kg. So there might be scope to looses some weight. Has it been re jetted etc, makes the torque curve a little broader.
dmrider_10
posted on 19/5/17 at 03:07 PM Reply With Quote
That's interesting because our car is willwoods front and hi spec rears on a live axle, supposedly the lightest setup? Maybe it's less than we thought or that's a full wet weight 🤔
Erm in a word no we haven't personally done it but it drives well.. Probably should get it on a dyno really. I don't suppose you know what size jets you ended up with? I have noticed sometimes on track that with a lot of overrun and then back on the throttle it can seem slightly hesitant, not lumpy but just slightly held back for a second
posted on 19/5/17 at 03:27 PM Reply With Quote
In a word, no. Making a new subframe for a more modern engine is going to be the easy part compared to plumbing in fuel injection, new exhaust, new cooling pipe runs etc.
sam919
posted on 19/5/17 at 03:37 PM Reply With Quote
I'll check at some point this week. I have the remaining needles and jets in the pack. A quick call to AB would get a quicker and more informative answer. Ill have a look though 👍
Ugg10
posted on 19/5/17 at 03:45 PM Reply With Quote
Maybe a chat with these guys http://www.holeshotracing.online/pdf/turbo-pricelist/tbikehonFireblade91_98_160126.pdf
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
sam919
posted on 19/5/17 at 04:31 PM Reply With Quote
919 gearbox isn't that suitable for higher torque
