Author: Subject: Decent exhaust pipe cutter
Shooter63
posted on 3/6/17 at 05:04 PM Reply With Quote
Can any of you guys recommend a decent exhaust pipe cutter must be able to cut 2.5" diameter stainless steel.
Shooter
craigdiver
posted on 3/6/17 at 06:51 PM Reply With Quote
Grinder + thin cutting disc???
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
posted on 3/6/17 at 07:48 PM Reply With Quote
I use the Silverline tail pipe cutter makes a clean cut if you don't rush it, but I have never tried it on SS
[Edited on 3/6/17 by britishtrident]
Smoking Frog
posted on 3/6/17 at 08:19 PM Reply With Quote
Same as above.
Wrap a sheet of A4 paper around the tube to get a even cut.
Mash
posted on 3/6/17 at 09:01 PM Reply With Quote
I bought an Evolution chop saw, recently, its really good and cuts tube really cleanly, at any angle you like.
I haven't tried it on SS either, but provided you get the corect blade I reckon it would do that too.
I got it from the Bay, refurbished for a really good price too
paulc
posted on 3/6/17 at 09:35 PM Reply With Quote
made all the cuts on mine with a hacksaw.
Found a web app that prints out templates for angled cuts.
Put in the tube diameter and the angle you want, print out the template, wrap it round the tube.
907
posted on 4/6/17 at 02:55 AM Reply With Quote
Band saw with a bi-metal blade.
Lotus 907 manifold
ianhurley20
posted on 4/6/17 at 08:00 AM Reply With Quote
Its called tube miter https://www.ozhpv.org.au/shed.html
posted on 4/6/17 at 03:23 PM Reply With Quote
Ditto - I bought an Evolution saw new from Screwfix a few years ago. It cuts wood and metal cleanly with the same blade.
