Author: Subject: 4A-GE Conversion Kit for Phoenix / Fury (engine mounts, exhaust manifold, clutch, propshaft, flywheel, bellhousing, transmission
reb
posted on 4/6/17 at 09:44 AM Reply With Quote
4A-GE Conversion Kit for Phoenix / Fury (engine mounts, exhaust manifold, clutch, propshaft, flywheel, bellhousing, transmission with straight cut gears)
Hello,
I am converting to a bike engine an hence I am selling the stated below parts which will enable you to install a Toyota 4A-GE engine and a Ford Type-e 4 speed transmission into your Phoenix or Fury.
These parts were installed in a Phoenix so they will probably fit a fury as well but I can not guarantee this.
If the gearbox is overkill for your needs, you can buy the kit without it!
- Engine mounts for 4A-GE engine (you will need to weld two simple steel plates on your frame to be able to mount these, see pictures)
- Exhaust manifold "4 into 1 race" design, very well made, no cracks
- Propshaft (will sit perfectly between a 4 speed type-e transmission and a Sierra diff)
- Lightweight flywheel (stock 4A-GE one, but machined extensively)
- Clutch (special clutch from fensport.co.uk, clutch cover will suit 4A-GE flywheel, clutch plate will match Ford type-e spline, 7mm thick.)
- 4A-GE transmission bellhousing to Ford Type-e transmission
- Ford Type-E 4-Speed Rocket transmission with straight cut Tran-X Synchro Gears, Ratios are: 2.54 - 1.66 - 1.255 - 1, BHP Rating 230-240 (approx.)
The transmission is in a good shape and all gears are engaging very smoothly and it doesnt make any strange sounds.
However it is leaking slightly between the bellhousing and the transmission, hence a brand new and large set of gaskets is included.
This is pretty much a complete kit, the only part which you require is a clutch release bearing which you can get from burtonpower.
Total price (including shipping): GBP 1500.00
All parts including bellhousing but without transmission (including shipping): GBP 700.00
[Edited on 4/6/17 by reb]
reb
posted on 13/6/17 at 09:12 AM Reply With Quote
Update: The installed tran-x gears are 2.48 - 1.69 - 1.28 - 1, very close to the stock rocket gear ratios which are 2.54 - 1.66 - 1.255 - 1
Here the pictures again as the ones from the first post seem to be down:
upload pic
[Edited on 13/6/17 by reb]
ian.stewart
posted on 13/6/17 at 06:38 PM Reply With Quote
U2U sent
Something different, Very different..............
ttalps2000
posted on 26/6/17 at 10:57 AM Reply With Quote
willing to sell the manifold seperatly? ?
1960dave
posted on 15/7/17 at 03:56 PM Reply With Quote
Did you ever sell this?
reb
posted on 15/2/18 at 04:20 PM Reply With Quote
Still available!
reb
posted on 13/3/18 at 12:40 PM Reply With Quote
Just the exhaust manifold and the engine mounts left now.
1960dave
posted on 13/3/18 at 12:47 PM Reply With Quote
How much for the engine mounts?
reb
posted on 17/4/18 at 07:43 AM Reply With Quote
I prefer to sell both the mounts and the exhaust manifold together, if someone buys the exhaust manifold and does not want the mounts I can sell them separately.
1960dave
posted on 17/4/18 at 08:32 AM Reply With Quote
How much?
