<<  1    2  >>
Author: Subject: Alignment done - steering off centre
Banana
posted on 4/6/17 at 02:23 PM Reply With Quote
Just had my Indy blade's geometry checked and tweaked,
Set things back to neutral toe and 1 degree camber all round.
The rear drivers side had 8mm of toe in, which i couldn't adjust.
However to drive the car straight the steering wheel is at 11 oclock, although the car tracks straight with my hands off the wheel.
Would this be the rear toe on the right hand side be causing this - and i am essentially counter steering to make it go straight?
If so, id have thought it wouldn't like going straight ahead with my hands off teh wheel.
Im running 14" wheels - what do we guesstimate would be the correct size shim to bring the rear wheel to straight? Im thinking 2mm.
cheers
[Edited on 4/6/17 by Banana]
40inches
posted on 4/6/17 at 02:32 PM Reply With Quote
Did they lock the steering wheel in the central position, when they did any adjustments?
SJ
posted on 4/6/17 at 02:34 PM Reply With Quote
Unless the guys who did the set up centred the steering wheel after adjusting the track rod ends the wheel is likely to be out a bit. Easiest way is to take the wheel off and put it back on in the desired position.
Banana
posted on 4/6/17 at 02:35 PM Reply With Quote
Sort of, we centered it before tightening things up. Then measured everything again at the end with the wheel central.
40inches
posted on 4/6/17 at 02:40 PM Reply With Quote
The steering wheel should be locked with a T bar, wedging it to the drivers seat.
Otherwise as SJ says.
Banana
posted on 4/6/17 at 02:41 PM Reply With Quote
But the string the box was created and everything measured when the wheel was centred, so surely just moving the steering wheel would mean im driving around with the wheels on the piss, and just masking the issue?
40inches
posted on 4/6/17 at 02:45 PM Reply With Quote
If the steering wheel wasn't locked, it WILL have moved when making adjustments.
Just take it off and refit straight, or adjust the track rod ends equally at both sides.
Banana
posted on 4/6/17 at 02:59 PM Reply With Quote
Ah i good idea.
Although, as i said everything was checked at the end after all being tightened up. So not sure how the steering wheel would have moved.
cliftyhanger
posted on 4/6/17 at 03:03 PM Reply With Quote
But importantly, what are you doing about thh 8mm toe in at the rear? that REALLY needs sorting, one way or another.
Banana
posted on 4/6/17 at 03:12 PM Reply With Quote
Shims. But i need to figure out what thickness would give me the required movement.
Is possible the rear right toe in could be casuing all this?
Say the wheel was central and the front wheels tracked - would that rear toe in be enough to cause me to need to counter steer?
Slimy38
posted on 4/6/17 at 03:16 PM Reply With Quote
I was going to say, there seems to be an awful lot of focus on the steering wheel, when an 8mm toe in at the rear will cause the thrust angle to be out (which might actually be the reason why you're driving at 11 o'clock). I had a bump in my car where the rear wheel looked almost straight, but I had to drive it home at a 45 degree angle to compensate!
You'll have to calculate what shim you need. If you measure the distance to the tyre and then the distance to the hub, and use that ratio on the 8mm to get what you need. I would expect it to be closer to 1mm than 2mm.
Banana
posted on 4/6/17 at 03:25 PM Reply With Quote
Indeed, I'm going to address that before changing the front.
Slimy38
posted on 4/6/17 at 03:54 PM Reply With Quote
Originally posted by Banana
Indeed, Im going to address that before changing the front.
But is it likely that toe in would cause me to have to counter steer? Assuming everything else is straight.
8mm toe in means that the thrust angle will be towards the left. The caster angle on the front wheels means that they will try and match the left angle, and turn slightly left. That will cause the steering wheel to move left, and I'd bet tuppence 8mm on the rear results in an 11 o'clock steering wheel position. You car will be pointing very slightly right as it's driving forward.
I'm oversimplifying things a lot, but it's a little more than a coincidence.
posted on 4/6/17 at 04:16 PM Reply With Quote
I had very slight toe out on my car which I corrected using shim stock ISTR the Sierra owners forum may have a rough guide to shim thickness?
Banana
posted on 4/6/17 at 04:41 PM Reply With Quote
Yep, its essentially steering from the rear.
From first glance, it seems i can get away with just slackening the hub nut and remove the four bolts attaching the hub to the upright - Insert shims, and refit bolts.
Am i missing something? Seems to easy..
SteveWalker
posted on 4/6/17 at 05:54 PM Reply With Quote
There are a number of threads on RHOCAR relating to shimming hubs - even if they are referring to shimming the top out to correct camber. They tend to use machined, u-shaped shims which slope from the think edge to the thin ends of the U. I presume that they are trying to avoid flat shims at one edge leaving large stress concentrations where the hub is only supported on the edge of the shim. Whether this is a real problem or not, I don't know.
posted on 4/6/17 at 05:59 PM Reply With Quote
Before starting any adjustments check the rack is centralised -- ie the steering wheel postion on left full lock should be an exact mirror image of the position on right full lock.
posted on 4/6/17 at 06:14 PM Reply With Quote
When I did mine I didn't touch the hub nut, there was enough room to insert the shims just by removing 2 of the bearing housing bolts and loosening the other 2 .
Banana
posted on 4/6/17 at 07:21 PM Reply With Quote
Thanks for confirming - so experimenting with different shims shouldn't be too tricky it seems.
Im sure i read this was a pig of a job..
Thanks Steve, i have been trawling the RHOC forums. Angles shims would be preferable, and once ive established the correct thickness thats needed, i will upgrade to these.
Banana
posted on 4/6/17 at 09:51 PM Reply With Quote
So i managed to add toe out with 2 x 1mm shims, before it got dark. After a quick blast, this in turn has almost centered the steering wheel!
Seeing as the other three wheels have neutral toe, im going to shim the one wheel out fractionally more until the steering wheel is central and use this as a rough guide to having achieved matching toe on the rear. Then take it back for measuring and see where i am.
Banana
posted on 5/6/17 at 10:05 AM Reply With Quote
Been thinking about this shimming lark - Surely even if wedges are used, the main problem with this is how the bolt head is not sitting flat when tightened down.
It can only go into the thread straight, so a correctly angled washer would need to go under the bolt head really.
Has anyone done this or worried about it? I imagine the bolts are strong enough tbh, but belt and braces and all that..
Banana
posted on 7/6/17 at 06:58 PM Reply With Quote
Thought id update this, as it might help someone in the future.
It does indeed seem to be the rear toe on one wheel which was throwing my steering wheel off center.
After a few attempts, i found 2 x 1.2mm washer have bought the toe to neutral, as best i can measure, and corrected the steering wheel to almost center.
Im mindful of thrust angle though, so im double checking my rear wheels from all wishbone mounts and an imaginary center line.
This also confirmed the toe in on the offside, and neutral toe on nearside as per the alignment check i had.
After the washers were added, this bought the offside to neutral, with equal measurements to the wishbone mounts/center line.
Does this sound correct to you guys? I don't think there is any other way of checking/adjusting thrust angle is there?
gremlin1234
posted on 7/6/17 at 07:40 PM Reply With Quote
remember, the tyres may have worn a bit/a lot while the alignment was significantly out. so I suggest you run it for a reasonable distance, (as now it is close to what it should be) and then check/adjust again
Banana
posted on 7/6/17 at 08:49 PM Reply With Quote
Thankfully ive done very little miles on these tyres.
Need to get a full contact shim next, as washers are a bodge.
Does the way i checked the thrust angle seem correct to you?
gremlin1234
posted on 7/6/17 at 09:11 PM Reply With Quote
its best to check alignment in 'normal running condition' ie you in the drivers seat.
[Edited on 7/6/17 by gremlin1234]
<<  1    2  >>
