New Topic New Reply
Author: Subject: Projector headlight washers
pekwah1
posted on 6/6/17 at 09:26 PM Reply With Quote
Hi guys,
I've just been reading the IVA manual and can't see anything specific for projector headlights.
It won't fall under gas discharge as I plan to use standard halogen bulbs.
However I know that for MOT you would need washers if you have projectors, is this he case for IVA?
theduck
posted on 6/6/17 at 09:34 PM Reply With Quote
Are you sure about that? Some renault clips came with projectors and not headlight washers. Thought it was only HID that needed washers?
pekwah1
posted on 6/6/17 at 09:40 PM Reply With Quote
Ah, maybe im wrong then, just noticed that all cars I've ever seen with projectors have had washers as well, maybe they just happen to have HIDs as well...
gremlin1234
posted on 6/6/17 at 09:49 PM Reply With Quote
the mot manual only refers to headlight washers on hid and led lighting, and even then only when fitted
[Edited on 6/6/17 by gremlin1234]
loggyboy
posted on 6/6/17 at 10:29 PM Reply With Quote
As above, Its only HID that should have washers and self leveling system. However its only a MOT failure if its clear they have them but they dont work. So you can still have HIDs with no washers if the washers purposefully and fully removed, or clearly never fitted.
[Edited on 6-6-17 by loggyboy]
Mistral Motorsport
New Topic New Reply
