Author: Subject: autodata users
john_p_b
posted on 8/6/17 at 07:44 AM Reply With Quote
autodata users
Morning all
i'm looking at investing in a autodata subscription at work, my job has evolved recently from being a pretty run of the mill service tech to taking on a lot more diagnosis, repair and electrical work.
The question i have at the moment is how up to date is Autodata? yesterday i had a brand new BMW 520 in for a crash camera to be installed but ended up having to turn it away as i had absolutely no info about where to pick up a switched feed to power the camera from and i'm not a believer in just probing into any old wire causing an upset somewhere!
would autodata be the answer to my problems or are there any other resources out there that would help? i've no issue in paying for the info as long as it's going to do the job i need it to do!
built a car, built a home, had a family. lost the family, lost the home, still got the car.
ian locostzx9rc2
posted on 8/6/17 at 03:15 PM Reply With Quote
I use E technical and I have used autodata both have holes and they more than likely wouldn't be current with a brand new car ,I've found E technical ok for me and it's slightly cheaper both companies offer a free months trail so maybe worth having a look .
obfripper
posted on 8/6/17 at 06:39 PM Reply With Quote
I've used autodata and haynes pro which has the same data source as e3, they are both lacking in wiring diagram coverage. I would say that autodata is more comprehensive for wiring diagrams, the technical diagrams with haynes/e3 are useful for tightening torques for specific bolts and cover alot more than autodata.
Another system to consider is wurth WoW, the data they use is sourced from autodata and it has diagnostic software as part of the system. IIRC it works out about £50+vat a month plus the diagnostic head, that's about £1500 and the software run on windows and uses bluetooth for connection.
Also no internet connection is required so still works if there's a power cut or internet outage, that is a major bugbear with autodata and haynes nowdays.
Dave
bi22le
posted on 8/6/17 at 08:28 PM Reply With Quote
Hmm. Granted I am talking over 12 years ago but I would of probed that!
A switched live and a constant would be easy I would of thought.
What worried me, even 12 years ago, was panel removal. The new mini is a great example, youtube it before hand or you WILL break something. Once you know, it is easy.
Please read my ring story:
john_p_b
posted on 12/6/17 at 06:18 AM Reply With Quote
to an extent i did! the only thing i could actually get at was the back of a fusebox in the drivers footwell but every single wire into it was permanently live!
also didn't help the job that the driver of said car who is a company director was stood over me the entire time harping on "i knew this would be a f**k up right from the start!"
