Author: Subject: Wilwood calliper inlet adapters needed
ste
posted on 13/6/17 at 04:14 PM Reply With Quote
I need two 27x1/8" NPT tapered thread to 3/8"x24 45 degree fittings.
I have straight ones and 90 degree ones but neither are suitable
russbost
posted on 14/6/17 at 07:46 AM Reply With Quote
Not aware of 45 degree being available, probs with any angle on a tapered thread is that you may not be able to get the union to the correct angle & still get it to seal.
If you use the straight adapters could you not use a bend on the end of the flexy? If so Oli at Furore Products could do hoses for you or, possibly, modify what you already have?
ste
posted on 14/6/17 at 01:33 PM Reply With Quote
I've just had the flexis made up by oli, one of the mudguard brackets is just in the way. I'll probably modify those instead of the hoses, it's just a 45 degree fitting would save any messing round
