Author: Subject: Clipping cable conduit
APR
posted on 14/6/17 at 01:14 PM Reply With Quote
How have people fixed the cable conduit to their chassis. Is cable ties Iva friendly down the tunnel ? Or is it P clips all the way ??
mcramsay
posted on 14/6/17 at 02:28 PM Reply With Quote
P clips look good but if you need to get at wiring within the split conduit it's a pain. I used self mount cable tie bases which have a barb that pushes into a 5mm hole,the cable tie also has a release mechanism so it can be quickly undone.
posted on 14/6/17 at 03:24 PM Reply With Quote
Cable ties are certainly cheap and quick, but you have to cut and replace them if you want to make wiring changes in the conduit.
P-Clips might take a little longer to install, but they can typically be accessed/replaced for any wiring changes.
APR
posted on 14/6/17 at 03:33 PM Reply With Quote
It's mainly I don't want to drill more holes in the chassis than needed and for Iva purposes
loggyboy
posted on 14/6/17 at 04:08 PM Reply With Quote
assuming you have holes for brake and fuel lines, combine 2 p clips to become '8' clips with bolt/rivet thru the centre.
Mistral Motorsport
