Author: Subject: Gasket sealer
starterman
posted on 18/6/17 at 05:53 PM Reply With Quote
Gasket sealer
As per the title can anyone recommend a good gasket sealer please?
bonzoronnie
posted on 18/6/17 at 06:07 PM Reply With Quote
Blue Hylomar or loctite instant gasket are my 2 favorites.
starterman
posted on 18/6/17 at 06:16 PM Reply With Quote
Thank you. My biggest concern is for the metal to ally gasketless joint on my black top zetec sump.
bonzoronnie
posted on 18/6/17 at 06:37 PM Reply With Quote
Some manufactures call for a specific product for metal to metal faces.
May be worth giving your local ford parts dept for a recommendation.
I doubt it would be any more expensive than buying sealants in the likes of halfrauds.
Sure one of the Zetec gurus will give you the best product to use.
tims31
posted on 18/6/17 at 07:52 PM Reply With Quote
I've used this on my sump -
Ali to steel on a blacktop Loctite Black sealant and not had any problems
Also available from Halfrauds for £6
[Edited on 18/6/17 by tims31]
Build: http://www.martinsfurybuild.co.uk/
posted on 19/6/17 at 10:54 AM Reply With Quote
Yes the Black Loctite sold be most motor factors is suitable I have also used the Grey Loctite for a couple of Nissan gasketless sump joints.
Oddified
posted on 19/6/17 at 09:03 PM Reply With Quote
Loctite 5926 is very good.
Ian
phelpsa
posted on 20/6/17 at 05:49 AM Reply With Quote
Ian
2nded
