Author: Subject: Blackbird help
Indybird88
posted on 27/6/17 at 05:38 PM Reply With Quote
Blackbird help
His guys and girls.
Having a bit of issue with my bird indy.
First off, has anyone with a blackbird carb model running it without an air box? If so how ?
Basically I have an issue when driving it will not rev over 4k, it bogs and fouls a lot.
I've read a lot about airbox differential pressure with the carbs and needing an airbox I'm getting stumped I'm running bike fuel pump with regulator and I've got a facet too no different I've tried a lot of things but I'm running out of optons. I just want to know if it will work if I need an airbox.
Any help would be great even if someone is close by with one.
Liam
CosKev3
posted on 27/6/17 at 06:13 PM Reply With Quote
Has it been rejetted?
Indybird88
posted on 27/6/17 at 06:24 PM Reply With Quote
Not yet no but it won't even rev properly standstill. It bogs droppe's the revs then picks up again. I know it will need re jetting but surely not to just run?
ian locostzx9rc2
posted on 27/6/17 at 06:39 PM Reply With Quote
Sounds like the carbs need cleaning
CosKev3
posted on 27/6/17 at 06:40 PM Reply With Quote
No airbox could well be the issue as you think,as it's just like running a open foam filter.
Have you got a manifold on it?
Indybird88
posted on 27/6/17 at 08:03 PM Reply With Quote
Yeh I've got two set of carbs both spotless.
Do you mean in or ex manifold? Its a blackbird engine so bolt on.
May I ask what happens with an open foam filter?
[Edited on 27/6/17 by Indybird88]
CosKev3
posted on 27/6/17 at 08:15 PM Reply With Quote
Just causes running issues until the carbs are rejetted correctly.
Exhaust manifold also alters the way the engines run,the ones used in a car set up
[Edited on 27/6/17 by CosKev3]
Indybird88
posted on 27/6/17 at 08:33 PM Reply With Quote
Yeh I have a Scottish kit car manifold. So do you think if I reject it it would rev properly without the filter?
Thanks for your help so far
feckn7
posted on 27/6/17 at 09:26 PM Reply With Quote
I have a carb'd blackbird and have found that they are very fussy when it comes to jetting.
Changed the muffler - re-jet the carbs and adjust needle height.
Changed filter from socks to large UniFilter unit - re-jet the carbs and adjust needle height
When I had the sock filters I had to go quite big jets. The UniFilter - smaller jets (but still bigger than standard)
As my filter(s) are protruding through the bonnet and in the airflow, I found the UniFilter to work better as its effectively a large foam airbox which seems to give the carbs less disturbed air.
CosKev3
posted on 27/6/17 at 09:27 PM Reply With Quote
It's hard to say for sure,but bike carbs/engines do behave strangely in a lot of cases once fitted in a car until the fueling is sorted correctly
CosKev3
posted on 27/6/17 at 09:29 PM Reply With Quote
There you go someone with some Blackbird specific info/experience!
Angel Acevedo
posted on 27/6/17 at 10:26 PM Reply With Quote
Line of action.
- Clean
- Adjust float height.
- Ensure equal jets all carbs.
- Verify accel enrichment pump dumping fuel.
- Ensure equal butterfly opening.
- balance carbs.
- adjust Idle.
- Adjust mixture (is it possible on those carbs?)
Then you may go about working on jet size...
There are a couple of ways...
Old school reading plugs
or Rolling Road..
HTH
Indybird88
posted on 28/6/17 at 08:33 PM Reply With Quote
Thanks guys for the help. I need to get in touch with dynojet then.
So is it a bit like mapping out an air box with the jets?
Sorry to be dumb.
feckn7
posted on 28/6/17 at 09:52 PM Reply With Quote
There's a fair bit of trial and error involved.
The standard jets on my Blackbird are 142 for 1 & 4 and 145 for 2 & 3
When I had the sock filters and my first exhaust system I ended up with 162 on all 4 with the needles raised (washers as my jets don't have a series of slots)
Changing the muffler required re-jetting to 156 (I think) and the needles lowered slightly. Changing the filter then required re-jetting again (152 from memory) and the needles back at standard.
Also had to adjust the idle jet screws each time.
It's still not perfect - running a little rich, but I'm happy with how it goes. Running a little rich is a lot safer than running lean
