Author: Subject: LED current limiting resistor calculation
Slimy38
posted on 8/7/17 at 10:07 AM Reply With Quote
I have four LED's that are 1.35V and 100mA. They need to be powered off USB, so 5 volts. Normally I've used a current limiting resistor to protect things, but I can also see that 4 x 1.35 is more than the supply voltage.
So first thing, is a current limiting resistor required if I run them in series? If it's safer to have a resistor, what combination of series and parallel would be best, and how do I calculate the value of the resistor? I have a decent range of resistors, but they're all 1/4 or 1/8 watt so I'll need to keep the overall power down. It'll also save my USB port too!
ReMan
posted on 8/7/17 at 11:08 AM Reply With Quote
try this
http://led.linear1.org/led.wiz
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
AntonUK
posted on 8/7/17 at 01:57 PM Reply With Quote
Originally posted by ReMan
try this
after sitting here for 5 mins with a calculator, i should of clicked your link first. nice find thanks
Build Photos Here
coyoteboy
posted on 8/7/17 at 09:59 PM Reply With Quote
Worth noting that the more you can put in series the better as the total power wasted in the resistor will be lower, however production variation can limit this (when you get to 5+ is series you can see serious variation across them). In this case I'd be going 2x2
ReMan
posted on 8/7/17 at 10:52 PM Reply With Quote
Agreed
In fact, depending on these leds, you may get away with 4 in series and no resistor
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Slimy38
posted on 8/7/17 at 11:00 PM Reply With Quote
Agreed
That's actually what I've done, seems ok at the moment...
coyoteboy
posted on 9/7/17 at 12:27 PM Reply With Quote
Just be wary that with no limiting resistor, if one led goes into thermal runaway you will pop the supply.
gremlin1234
posted on 9/7/17 at 12:47 PM Reply With Quote
could put a 250ma fuse in series
posted on 9/7/17 at 05:06 PM Reply With Quote
Agreed
Very bad idea unless running from a supply that has a suitable current limit. The forward voltage of an LED reduces with increasing temperature, and with no current limiting you very quickly reach a thermal runaway state.
coyoteboy
posted on 9/7/17 at 09:41 PM Reply With Quote
Fuse is too slow to protect most electronics. You should consider fuses just wire protection.
