Author: Subject: Engine mounts
bigwill64
posted on 8/7/17 at 09:08 PM Reply With Quote
Engine mounts
What engine mounts are people using? Book chassis pinto engine ? Mine appears to be really high and can't fit nose or bonnet at realistic height .
chris
posted on 9/7/17 at 09:23 AM Reply With Quote
you can buy engine mount kits which you cut and weld yourself or if you have a good friendly engineering company you know to supply bits of metal and do it yourself
or if its just the rubber mounts are to big i had three sizes to choose from when i fitted my engine
[Edited on 9/7/17 by chris]
bigwill64
posted on 9/7/17 at 09:46 AM Reply With Quote
Engine mounts
It's all mounted up already but when fitting nose and bonnet engine is too high the mounts it's on are about 100mm high look light Land Rover type I have other that are smaller probably about 50mm and they might be better.although I might have to shorten the sump looking at it from side.
